90 accord tranny problemstyflesh 07-13-2008, 05:44 PM tranny shifts fine through 1st and 2nd gears but wont up shift to 3rd and 4th and the sport mode light is on and wont go out, even manually shifting it wont go any higher then 2nd gear any suggestion???? wiseguy01 07-13-2008, 07:17 PM if the sport light is blinking then it indicates a problem that the tcm senses it could either be caused by the speedometer not working or a shift sylinoid is no good which in this case every gear 1-4 has one and they are located on the front of the trans and look like cylinders kinda like a c battery to diagnose the prob you would have to download the fsm for your accord but if i remember right the pigtail is located on the passenger side kick panel the kick panel would have to be removed though and its a blue pigtail and jump it with a piece of wire then if the s light starts blinking take it down it will indicate a trouble code but if the s light remains on then you might have the switch still on try turning the s light off there should be a switch on the side of the gear shift where you shift with your hand its kinda like turning off overdrive it will not shift to fourth if the s light is on maybe thats your prob tyflesh 07-13-2008, 10:32 PM thanks wiseguy, the light is not flashing it solid green, the switch is in the normal mode position not in sport mode, the speedo works fine it just wont shift up to 3rd or 4th, i seen the 4 sylinoids on the front ot the trans, and i also located the tcu..... i havent tried to jump the blue pigtail on the kick panel ProMan 07-14-2008, 04:03 PM Should be your TCM - Tranmission Control Module. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
