2000 camry outside door handle
rodchar
07-05-2008, 05:52 PM
hi all,
would it be difficult to replace the outside door handle (driver's door)? mine is half cracked off.
thanks,
rodchar
thanks,
rodchar
Mike Gerber
07-06-2008, 11:56 AM
Download the generation 4 service manual stickied at the top of this forum. It should have the information you need.
Mike
Mike
rodchar
08-04-2008, 08:08 AM
thanks for the tip,
rod.:wink:
rod.:wink:
Toyz4Boyz
03-30-2009, 08:32 PM
theirs like 10 manuals =( which one?
my door handle Just the part you put your fingers in to open broke off
so now i gotta use 2 hands n grab both sides to open it =\
Generation 4 ('97-'01)
Repair Manual (http://www.camrystuff.com/index.php?page=Gen4_Manuals)
Electical Wiring Diagrams (http://www.camrystuff.com/manuals/Gen4/99EWD.pdf)
Collision Repair Manual (http://www.camrystuff.com/manuals/Gen4/97-01_Collision.pdf)
'99 Owner's Manual
(http://www.camrystuff.com/manuals/Gen4/Miscellaneous/99_Camry_Owner_Manual.pdf)'99 Scheduled Maintenance Guide (http://www.camrystuff.com/manuals/Gen4/Miscellaneous/99_Scheduled_Maint_Guide.pdf)
TSBs (http://www.camrystuff.com/manuals/Gen4/Miscellaneous/TSBs.pdf)
then when i click repair manual it brings up
a list n i clicked on http://www.camrystuff.com/manuals/Gen4/Miscellaneous/Front_Rear_Door_Instrument_Panel.pdf
but i dont know what they call the outside door handle =\
'99 Owner's Manual
GSS123
03-31-2009, 08:38 AM
Door handles are not to hard to replace, the clips that hold the door panel on seem to change every 4 years so you have to determine the best way to remove them. Also a helper holding all the levers inside the door when you connect them to the new handle is nice to have. I just started taking parts off the door until I had access to where I needed to be.
There's just some things my kids don't seem to learn in school. In sub zero weather door handles sometimes need tenderness to open instead of overwhelming force.
Mike Gerber
03-31-2009, 11:09 AM
'99 Owner's Manual
I would download the repair manual and the electrical wiring diagrams and keep them for future reference.
Mike
'99 Owner's Manual
Mike
RIP
04-01-2009, 02:56 PM
The manual doesn't have a step by step procedure to remove the outside door handle. There are however two diagrams showing configuration of screws attaching the door trim panel and the handle itself. As GSS123 stated, you just take it apart till you get there. Once you open the manual select the "Body" file and go to page BO-11.
Just changed an outside drivers door handle on a 94 yesterday. Took me about two hours. I found removing the window glass gave me a little better access, at least to see the back side of the handle. Lower the glass half way, remove two bolts securing the glass to the track, pull the window out the top.
