View Full Version : Chevy 350 Edelbrock Aluminum Heads
HotZ28
07-04-2008, 10:35 PM
One set of nearly new Edelbrock Aluminum Heads. Used less than 200-miles. Removed to change engine over to lower compression heads for supercharger. Heads are in excellent condition! View the specs below. These heads are good for 30-40 HP over cast iron & 20-30 HP over Alum Corvette heads! PM or Email me @ Earledw1a@aim.com if interested. $750.00 firm, plus shipping, Paypal or Cash only, do not waste my time and I will not waste yours!
Fits the following:
CHEVROLET - 5.7 Liter CID 350 Engine Type V8 Engine Size 5.7L/350. Beginning Year 1987 Ending Year 1991 Engine Family Chevy small block Gen I Rocker Arm Mounting Style (application) Stud Application Notes Designed for Corvette/ Camaro, direct replacement, will not fit LT1. Also fits 1986 with stock aluminum head engines. Will only work with early style manifold with straight bolt patterns. Center Bolt Valve cover mount.
Part Number: EDL-60879
Cylinder Head Style: Assembled
Cylinder Head Material: Aluminum
Cylinder Head Finish: Natural
Combustion Chamber Volume (cc): 60
CNC-Machined Combustion Chamber: No
Intake Runner Volume (cc): 165cc
Exhaust Runner Volume (cc): 60cc
CNC-Machined Intake Runner: No
CNC-Machined Exhaust Runner: No
Intake Port Location: Standard
Exhaust Port Location: Standard
Spark Plug Style: Straight
Intake Valves Included: Yes
Intake Valve Diameter (in): 2.020 in.
Exhaust Valves Included: Yes
Exhaust Valve Diameter (in): 1.600 in.
Valve Springs Included: Yes
Maximum Valve Lift (in): 0.575 in.
Outside Diameter of Outer Spring (in): 1.450 in.
Damper Spring Included: No
Number of Springs Per Valve: Single
Retainers Included: Yes
Retainer Material: Steel
Locks Included: Yes
Lock Style: 7 degree
Valve Stem Seals Included: Yes
Valve Stem Seal Style: PC seal
Rocker Arm Studs Included: Yes
Rocker Arm Nut Thread Size: 3/8-24 in.
Rocker Arms Included: No
Rocker Arm Nuts Included: No
Guideplates Included: Yes
Guideplate Pushrod Size: 5/16 in.
Valve Cover Mounting Style: Centerbolt
Accessory Bolt Holes Drilled: Yes
Valve Guides Included: Yes
Valve Guide Material: Manganese bronze
Valve Seats Machined: Yes
Valve Seat Machine Style: 3-angle
Valve Seat Material: Ductile iron
Steam Holes Drilled: No
Oiling Style: Through pushrod
Machined for O-Ring: No
Heat Crossover: Yes
Cylinder Head, Performer, Aluminum, Assembled, 60cc Chamber, 165cc Intake Runner, Chevy, Corvette, Camaro 5.7L
http://img361.imageshack.us/img361/8798/edl60879wdn4.jpg
Related Links
Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free.
