1991 lumina problems # 2
Google
Web AF
1991lumina
07-04-2008, 06:34 PM
Ok welll you guys tried to help me before but i havent had time since then to do anything but the problem i am having is the the car will run perfect when you first start it up and drive it but when it gets warm it will run like crap and die when you give it gas, fuel pump has been replaced as long as with, throttle position sensor, map sensor, iac, fuel regulator, throttle position sensor connect, coolant temp and connector, i have absoutley no idea what could be wrong :banghead: ... the thing is engine light comes on after warm up and map sensor comes up and so does the throttle sensor and idle air temp sensor and they ALL have been REPLACED... ECM maybe? i dont know im leaving in 2 months for the service and i want it to be up and running for my family can use it, it is a 1991 lumina with 210k miles on it ive put to much money in it already and i just want to get the damn thing running :banghead: :banghead: :banghead: :banghead:
maxwedge
07-04-2008, 09:44 PM
No quick answer for this, try the tap test on the pcm, see if the engine responds in any way, those year pcms were troublesome. Use a screw driver handle and tap the case firmly, engine running, see if anything happens.
1991lumina
07-05-2008, 01:43 PM
where is the PCM and what does pcm stand for? im still learning about cars
1991lumina
07-05-2008, 01:46 PM
nevermind i know what it is...... should i try the tap test when the car starts to do its thing or just start it up and try it and where should i tap it at?
sad-lumina-owner
07-07-2008, 02:10 AM
thats odd: You have mentioned everything but the fuel FILTER...did you replace that? Cause if its clogged you get gas at low speeds but giving it gas might choke it down...
maxwedge
07-07-2008, 09:43 AM
Do the tap test when it is running, see if the engine responds in any way.
1991lumina
07-07-2008, 09:24 PM
yeah thats been replaced also
1991lumina
07-07-2008, 09:27 PM
ok well i put a new ECM in it today, i just went and bought one since i had bunch of coupons at a local part store and got it for pretty cheap and the car idles alot smoother and seem to run better buuuut it still doin what it is doin gave the engine codes 22,34,35 and all of them have been replaced but the connector for the map sensor has not been replaced and neither has the IAC sensor i was told that they all link together when you have a problem so i bought a map sensor connector today and plan on splicing that in tomorrow and cross my fingers to see what happens
1991lumina
07-08-2008, 11:09 PM
well im making progress, I was getting codes 22,33,34 well now im down to 34 i put a new connector on the map and that went off then i still got 33,34 then i adjusted the tps connector since i replaced it once and then that went off and now im down to 34 and i look at the wiring and it was the same deal as the others so since no part store around here sells it or wants a butt load of money for i have to order it online so im kinda anxious to see what happens
1991lumina
07-09-2008, 06:29 PM
just a question, would bad wiring connection for the idle control valve cause the car to die after it gets hot? the car idles high when you first start it and when you shift to drive it almost wants to die but once you take off its fine but car wants to take off when at a stop, but when it gets hot and comes to a stop it wont idle at all, the idle control valve has already been replaced along with bunch of other sensors, oh and i also get the engine code for the idle control valve
Google
Web AF
