89' XJ6 Jag Electrical Prbs Need Info/Help
Jaguar2008
07-02-2008, 01:12 AM
I have a 89 XJ6 Jag that has no dash lights,heater,radio, sunroof, or tail lights, I know my fuses keep blowing out when I try to replace them. I wanted to know if anyone else has experienced this problem with this type of Jag. I bought the car cheap -($500 cash) and thought it would last until I bought a newer car. That is really the only thing wrong, I replaced the master cyclinder head myself, and had a shop bleed the brakes. Thats working great, I also don't have a manual and I was lookin for some advice on this car.:banghead:
Thanks,
Jen's Jag
Thanks,
Jen's Jag
ZoomZoomMX-5
07-02-2008, 06:43 AM
You bought a 22 year old $500 Jag and are having electrical problems. Does it have the three-position lightswitch; dim, flicker, and off?
And you're posting about it in a model car section. :screwy:
djagman
07-25-2008, 11:32 PM
fir4st unplug the headlight switch.then replace fuse.then check ground on the fire wall/bulkhead.is just behind the head.after that post reply.
