Page updated on 04-23-2018
2000 s-10 fuses "ecm b" and "ecm 1"blowing
handy1
06-28-2008, 04:21 PM
my 2000 s-10 blew a fuse for "ecm b"the other day the truck died and the fule gage stoped working . i replaced the fuse and all was good. a couple days later the service engin soon light came on . i changed the oil and filter the next day i blew another fuse for "ecm 1" and now it wont run every time i hit the gas it blowes the "ecm1" fuse and dies. what are thees fuses for and how do i corect the problem?
MT-2500
06-29-2008, 09:11 AM
Engine size?
The onyy commom share on the fuses is the VCM/pcm.
If the only one blowing now is the EMCB?
It feeds fuel pump and VCM.
If only blowing when you hit gas may be the answer to problem.
Try easy down on gas and then hit it hard in gear or out of gear and in drive or reverse..
I would wiggle wiring and look for a short.
When giving it gas it may be moving the wiring and rocking the engine.
Got any bad engine mounts or transmission mounts?
handy1
06-29-2008, 08:15 PM
i dont know what size engine other than 4 cylinder
MT-2500
06-30-2008, 07:08 AM
The only commom share on the fuses is the VCM/pcm.
handy1
06-30-2008, 07:35 AM
what is " VCM/pcm"
MT-2500
06-30-2008, 08:12 AM
VCM/PCM = engine and transmission control computer
handy1
06-30-2008, 08:15 AM
great so it could be 1- the fuel pump, 2- the comupter, 3- faulty wireing, 4- bad sensors?
MT-2500
06-30-2008, 12:25 PM
Where do you get bad fuel pump or 4 sensors?
If it is blowing fuse you have something shorted.
If you would give us more info and details some one may be able to help you.
Good Luck
MT
handy1
07-01-2008, 07:26 AM
sensors and pumps are electrical when they go bad they become a short
MT-2500
07-01-2008, 08:19 AM
Not always
Almost Everything on it is electrical.
But only certain things on certain fuse circuits.
http://www.alldata.com/products/diy/index.html
Upper link Will help you find it.
Good luck
MT
