Programming procedures for 2004 camry remoteAstok 06-22-2008, 03:25 PM Just got a 2004 camry one remote works and one doesn't. Does anyone have programming procedures for these key fobs? Thanks a Lot Alan Hungrycat7 06-22-2008, 04:23 PM Here ya go! This should work for the 02-05 models. . . Good Luck! 1. Start with the following conditions: You are in the drivers seat. a. Key is out of the ignition b. Driver door is open (all other doors closed) c. Driver door is unlocked (other doors don't matter) 2. Insert and remove the key from the ignition twice within 5 seconds. 3. Close and open the drivers door twice within 40 seconds. 4. Insert the key into the ignition and remove it. 5. Close and open the drivers door twice within 40 seconds. 6. Insert the key into the ignition. 7. Close the door 8. Turn the key in the ignition on and then off. 9. Remove the key from the ignition. 10. The power locks should automatically cycle once to indicate that you have successfully entered program mode. 11. Within 40 seconds of the entering program mode. a. press both transmitter lock and unlock buttons SIMULTANEOUSLY for a duration of from 1 to 1.5 seconds. b. within 3 seconds, press the transmitter lock button for more than 1 second and release. c. If the transmitter has been sucessfully programmed, the power locks will automatically cycle once. If they cycle twice, the remote has not been accepted. d. If multiple remotes are to be programmed, repeat steps A-C. 12. Open the driver's door. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
