96 Lumina 3.1 with a rough idleNCSmarti 06-21-2008, 02:17 PM Im stumped. I have a 96 Lumina 3.1 with a rough idle problem. The car runs and idles fine in park and runs fine when moving, but once I stop with the brake pedal depressed the engine starts to run as if its missing. When the brake pedal is released the car goes back to normal almost immediately. I think its a vacuum problem and I have checked all of the vacuum lines and replaced a few, but the problem has not gone away. Could it be the EVAP Vacuum Switch or the EVAP Canister PURGE Valve? Since the brakes are involved could it be a bad Vacuum Brake Booster? I also noticed that there is a vacuum line coming off the bottom of the EVAP Vacuum Switch (at a right angle) that is not connected to anything. I appreciate your help. maxwedge 06-21-2008, 04:21 PM Take the vacuum hose off the booster, block it off and see how the engine runs. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
