383 procharger or turbo.....gorgepr 06-12-2008, 06:02 PM guys I'm thinking of building my lt1 to a 383 and I need your opinion plus the plus and cons of these options: an sts turbo charger, a front mount turbo, a procharger, or to run it on nitrous, its supposed to be a daily driver but I have another car so it would be a weekend driver. btw its an automoatic stieh2000 06-12-2008, 06:29 PM If its a DD, I'd go with nitrous becuase there's no need for those extra few 100+ horses all the time. poormillionaire2 06-12-2008, 06:57 PM I vote procharger. Turbos are ok, they have their place, but they require a lot more tubing and plumbing. If you have the time and money, a turbo is ok, but they are a lot more work. I would rather get an STS turbo than a front-mount turbo just for that very fact. Nitrous can be fun, but I think there are a lot more things to worry about with nitrous. You hear a lot more stories of nitrous killing a car than super/turbochargers. Purges do look kick-ass though. But you go have to incur the re-occuring cost of filling the bottle. lamehonda 06-12-2008, 07:31 PM Are you looking for a fast road car or something to take to the strip on weekends? I would go supercharger for everyday, and nitrous for the strip. Turbos can be awesome but require alot of work as previously mentioned. tripnips 06-12-2008, 11:02 PM personally id say the sts turbo because nitrous as mentioned before can really screw your car up quick and the superchargers use a belt off of the engine to feed the air into the engine so it takes some power away to make power so its not quite as efficient as a turbo. the only thing is are you looking for low end power boost or high end because the turbos mainly feed more power to the high end and superchargers mainly feed the low end rpms power. but a downside to turbos is you have to route an oil line to it to keep the bearings lubricated and its a good idea to use full synthetic just to be safe, and you should also let the vehicle its going into idle for a few minutes after the turbos used so the oil can keep the bearings lubed while its cooling down because its a common problem for turbos to fail if you just turn the car off without letting it cool down. its really not a matter of what other people think as much as what you are looking for. nitrous, pro-power anytime you need it:evillol: con-need to pay to fill it, really miffs the engine if you make a mistake turbo, pro-lots of high end power, very efficient con-need lots of plumbing, intercooler, wastegate, and a blowoff valve would be recommended, and the air can go back into the engine via the exhaust header(s) and blow the shite outta the engine supercharger, pro-lots of low end power where most of the power really needs to be put con-takes a little power from the engine to feed it more therefore not as efficient these are my understandings and as i wish i knew everything about cars i know i dont so if i messed up on anything or forgot anything feel free to correct me/add onto what i said... gorgepr 06-13-2008, 01:14 PM I like the rear mount turbo the best, because I have a broken buick that I made turbo so therefore I just need the pipes, intercooler, blow off, turbo timer, the turbo itself, and a few injectors that I already have, the nitrous option I trow it there just to add something but I think Ill go rear mount thanks for your opinions MrPbody 06-13-2008, 02:02 PM Turbos are more efficient, true enough. However, ProCharger is unique among superchargers and is nearly as efficient as a turbo and MORE effective. At "Super Chevy" (an oxymoron, to be sure), they (the ProCharger "people") had a Nova with a 383 in it. Without the belt, on 93 octane, it went 12.20s at about 110. Not bad, and it means this was no "econo-build" on the engine. They put the belt on and it went 9.40 @ 140, still on 93 octane. Pretty impressive. At Pontiacs In The Park, a '69 Firebird with a 461 CID street engine (93 octane, 2,400 RPM converter) went 8.22 @ 165. Again, with the ProCharger. ProCharger has the advantage of the blower by being belt-driven, but instead of rotors, it turns a "turbine", similar to a turbocharger. No lag, less drag. Best of all possible worlds... With the longer stroke of the 383, it wouldn't "like" the turbo as much as it would the blower. Nitrous is best described as "violent". VERY hard on parts. Horsepower RIGHT NOW! Pick yer poisen... Jim gorgepr 06-14-2008, 03:33 PM but if I left the engine as a 350 the turbo should work beter than on a 383?? GreyGoose006 06-15-2008, 11:39 PM its a matter of the range of air volumes the engine can flow. you see, a turbo has a specific range that it works best in. exceed this range, and the efficiency drops like a rock, and the intake charge begins to get excessively hot. a 383 is right about at the limit of requiring 2 turbos as opposed to one large ass turbo. the single large turbo might work on a 350, but there would be lag, and it would be straining at the high rpms. look at the turbos built for the 80's turbo buicks. like this http://www.cardomain.com/ride/322659 thats a 383 in a caprice classic with twin turbos. not a bad day. for simplicity though, i would recommend a dual stage nitrous setup, or a procharger. dual stage so that you can choose how much you need/want. 25 hp and 75 hp for example. or 75 and 150. pick your poision. Mr. Luos 06-16-2008, 11:48 AM Single front mount turbo. MrPbody 06-16-2008, 01:13 PM Sounds like you're hell-bent on the turbo. If you WANT a turbo, BUY A TURBO! Personally, I've seen far too many maintainence "issues" with turboes over the years, and far prefer the belt. But I just build them. I don't own OR drive them... My little P-Body has no blower of any description... (:- Jim ddnspider 06-16-2008, 03:13 PM my 383 turbo.spools hella quick and makes good power.i been running around like that for 2 years no issues. http://i5.photobucket.com/albums/y159/ddnspider/boosted%20pics/th_TTAdyno.jpg (http://s5.photobucket.com/albums/y159/ddnspider/boosted%20pics/?action=view¤t=TTAdyno.flv) http://i5.photobucket.com/albums/y159/ddnspider/boosted%20pics/underhood.jpg lamehonda 06-16-2008, 03:46 PM No one has really addressed cost. Aren't superchargers typically cheaper and lower maintenence. When is the last time you saw a blown supercharger? It just throws the belt sometimes right? Genopsyde 06-16-2008, 04:00 PM bearing can go in a sc lamehonda 06-16-2008, 09:36 PM how often does that happen? The SC doesn't spool up near as fast as a turbo right? and are we talking about replacing a bearing or the whole setup like you usually do with a blown turbo. ddnspider 06-16-2008, 10:04 PM how often does that happen? The SC doesn't spool up near as fast as a turbo right? and are we talking about replacing a bearing or the whole setup like you usually do with a blown turbo.if were talking about a procharger(ie centrifugal blower) then you are correct.blowers like that are setup so they make maximum boost at maximum rpm.thats why i like turbos.a properly sized turbo will have minimal lag or a low boost threshold and achieve maximum boost quickly. lamehonda 06-17-2008, 09:26 PM I personally like turbo lag color me odd. I like listening to it spin up waiting for that insane power to hit. I prefer that over the little notch of power I get with my car. I need a turbo from a semi is what I need. ddnspider 06-18-2008, 01:45 PM I personally like turbo lag color me odd. I like listening to it spin up waiting for that insane power to hit. I prefer that over the little notch of power I get with my car. I need a turbo from a semi is what I need.that turbo ebook that im on the cover of sold by junkyardturbos.com goes over practically every turbo out there including the Holsets,which are the ones people take off diesels to use. gorgepr 06-19-2008, 05:28 PM that is one of the turbos that I have it came out of a cummings engine or I can go small with a turbo from a porshe that I also have 89IROC&RS 06-25-2008, 12:59 PM as has been covered here, it really depends on where you want your power, and how involved an installation you are willing to put up with. Pro-charger - as stated, is a no brainer to install, is pretty reliable, and makes its boost at high rpms, meaning its great for the strip, but perhaps not the best for the street. Nitrous - makes awesome power at the push of a button, can be turned on and off, but needs to be refilled, and if it isnt done right, will scatter lots of peices of the engine. turbo - the most complicated install by far, but when properly built will spool up quickly and reach boost levels at useable rpms for daily driving. also the method of operation is arguably the most efficient. more so than even the pro-charger setup. hell, why not do all three and say darn the torpedo's full speed ahead ;) lamehonda 06-25-2008, 04:40 PM When you do a supercharger/ turbo set up, would you put the supercharger upstream from the turbo to get it spooled faster? I have seen a few cars running this setup. Whoaru99 07-16-2008, 08:41 PM cummings engine Sorry but this drives me nuts... it's Cummins, not Cummings... :slap: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
