1987 190eAmi 06-12-2008, 05:36 PM i have 190e it been sitting the garage for a while i tryed to start it the other day gave it a boost did not start so i put gas threw the carb it started for a while then dies i was wondering if the fuel pump is died or it could be a fuse sl65amg 09-18-2008, 03:14 PM Well first you should be able to hear the fuel pump if you get close to it. If its not running it could be your problem,or the fuel pump relay. If the pump wont come on,pull it out and put power to it and see if it runs. If the pump is good then its probably the relay. I might have one,if thats your problem. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
