94 camry 2 dr window passenager wont go down
Google
Web AF
pshsguy18
06-11-2008, 11:33 PM
Ive just fixed my driver side window regulater and I thought my passenger side was the same thing but I check the volts to the power to the motor on the passenager nothing there. What can I do to fix this some one told me it could be the master switch is this true or can it just be broken wire? How can I fix this a easy way please help me out? Ive got a red wire and green wired gone to the plug let me know thanks
Brian R.
06-12-2008, 09:17 AM
Many times what is broken is a wire in the wiring harness as it passes through the area near the door hinge.
jdmccright
06-12-2008, 03:26 PM
The wiring harness running from the driver's door to the left kick panel by the driver's left foot will develop breaks in the wires due to fatigue from opening & closing the door for 14 years. You might be able to confirm it is there by pinching/rolling the harness between your fingers at the rubber sheath while trying to operate the window.
Repair consists of either splicing in new wires or replacing the entire harness. New ones are hard to find and pricey, used ones will likely have the same fatigue issues unless you can confirm it came out of a pristine, low-mile car.
Google
Web AF
