Removing Grill-2004 Blazerjsgold 06-11-2008, 12:41 PM just got a 2004 Blazer to replace the old tired 93 S-10 Blazer. I a going to add a tranny cooler, but have a question on the grill. On my 93 it was easy to remove the screws and pop the grill off for this, but how big a deal is this on a 2004? I see no screws at all on this one, and do not have a GM manual for it yet. Can I add a cooler without doing this? ricksza 06-12-2008, 12:40 PM To remove the grill: Open the hood. Remove the grille by pulling it forward out of the radiator support. Disconnect the headlamp washer filler hose from the grille, if equipped. Remove the park/turn signal bulb assembly from the lens. Remove the fog lamp bulb assembly from the lens, if equipped. jsgold 06-12-2008, 12:43 PM Does it simply snap out, or are there hidden screws I can't see or perhaps special clips?? ricksza 06-13-2008, 05:49 AM They are V shaped clips. Usually with a slight pull, they will disengage. Other times they are extremely tight. At that time, it sometimes helps to get between the pieces with a flat tool to spread them apart and hope that nothing breaks. jsgold 06-13-2008, 08:51 AM Thanks for the information! I will be careful when removing. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
