I need help with a problem
stapler
06-11-2008, 09:17 AM
no injector pulse
no crank rpm
vehicle has spark
serge_saati
09-28-2008, 11:38 PM
It's a problem with your crankshaft sensor and camshaft sensor or the cables which connect them are not plugged correctly. Or the cables are damaged.
I suggest you to verify first these cable from beginning to end. If it's good, check the contuinity.
Then if this all ok, test the 2 sensors. If they are bad, replace them.
