toyota problembruce prophet 06-09-2008, 09:06 PM i have a 1998 tercel which is acting up when driving. It bucks and shakes for a bit then clears and is okay . if i down shift it goes normal until overdrive then the problem returns. I put tsp ejector cleaner in the gas tank it seems to help. This problem occurs at any speed and frequently.. can you help?? also i bought a obd2 code reader but i cant find the plug receptacle.. it is not under dash drivers side.can you help on this one too??? bruce jdmccright 06-19-2008, 12:07 PM A bit late, but a search shows it to be on the far left of the driver's side knee bolster, behind the fuse panel cover. Hope this helps! bruce prophet 06-24-2008, 06:37 PM thanks to jdmccright for solving my toyota problem re. obd2 code reader bruce vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
