Blazer problem under accellerationjessemace57 06-09-2008, 07:20 PM I have an 01 blazer Xtreme with a 4.3l and an automatic tranny. A few days ago it started to act funny under accelleration but only if I push the throttle down more than about 20% it feels like its misfiring. It through the code P0300 which is a random cylinder misfire. I have platinum four plugs in the motor. I have also tried changing the ignition control module, which didnt work. I don't see any spots where the wires have arched. If the A/c is on the problem is worse, as well as going up hills. I am not sure what it could be. Has anyone had this problem before? Anyone know what it could be. Someone told me it might be the PCM, but that is pretty expensive to replace. If anyone could help I'd Greatly appreciate it. Thank you all very much for your time. MT-2500 06-09-2008, 07:55 PM I have an 01 blazer Xtreme with a 4.3l and an automatic tranny. A few days ago it started to act funny under accelleration but only if I push the throttle down more than about 20% it feels like its misfiring. It through the code P0300 which is a random cylinder misfire. I have platinum four plugs in the motor. I have also tried changing the ignition control module, which didnt work. I don't see any spots where the wires have arched. If the A/c is on the problem is worse, as well as going up hills. I am not sure what it could be. Has anyone had this problem before? Anyone know what it could be. Someone told me it might be the PCM, but that is pretty expensive to replace. If anyone could help I'd Greatly appreciate it. Thank you all very much for your time. Anyone that uses the plat 4 will have them problems. Pitch the plat 4 in the trash can and get the good Ac -delco plugs the ac -delco book calls for. If that does not do it post back and someone will help you. jessemace57 06-09-2008, 08:00 PM I have been using them for over a year. Do they normally take that long to make this problem? 3rdgentug 06-09-2008, 09:10 PM i agree ditch the platinum plugs get some good ac delco plugs or ngk's be sure the are gapped correctly old_master 06-09-2008, 09:41 PM P0300 can also be caused by faulty plug wires and/or distributor cap and rotor. Again, don't waste your money on aftermarket stuff, stick with AC Delco. jessemace57 06-09-2008, 09:52 PM Something I forgot to add earlier is that when it starts acting funny the check engine light starts to flash. Then my ABS and brake light come on. I don't know if the ABS light has anything to do with it. Thank you all for your help. old_master 06-09-2008, 10:33 PM It's normal for the SES light to flash when any P0300 series DTC is being set. Take care of that problem first, then deal with the ABS light...if it still flashes. MT-2500 06-10-2008, 04:00 PM I have been using them for over a year. Do they normally take that long to make this problem? It all depends.But you are luckie to get a year out of them. Pitch them in the trash can or take them backmto the store that sold them to you and demand your money back on a good set Of the rigfht AC-delco plugs. As old master said other tihings can cause a miss. Bad wires,low fuel pressure,Maf sensor and camshaft retard setting. But Bosch plat 4 are at the top of the list. Good luck \and let us know how it goes. MT jessemace57 06-12-2008, 11:09 AM I pulled the distributor cap off yesterday, It looks shot and the rotor button isn't too much better. So I cleaned them both and it works somewhat better. The caps diodes were worn down so I really need to replace both. Also My coil is really loose if I am gonna replace it should I go aftermarket with an Accel? And what Accel should I buy? Thank you all for all your help. I am gonna change the plugs and wires when I change the cap, rotor button and ignition coil. MT-2500 06-12-2008, 12:22 PM Ac-Delco is the only way to go. \MT leadman 11-07-2008, 12:15 AM i have a 2003 blazer xtreme and i got the same problem when i accellerate from a dead stop the engine is sluggish sometimes and on the highway at about 65 - 70 mph -the service engine light will flash for about 3-5 min and then stop but then if i accelerate faster it will start to blink again. WHAT DO I DO??? MT-2500 11-07-2008, 09:51 AM i have a 2003 blazer xtreme and i got the same problem when i accellerate from a dead stop the engine is sluggish sometimes and on the highway at about 65 - 70 mph -the service engine light will flash for about 3-5 min and then stop but then if i accelerate faster it will start to blink again. WHAT DO I DO??? Flashing light is a missfire or engine running rich and system is shutting down to save the cats. For help on yours start a New Thread/post and some one will help. Also check codes and post back in the New thread the codes and mileage and engine info and tune up histoty. And someone will help you. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
