recharging 2000 isuzu rodeojp41 06-09-2008, 09:47 AM :crying: i have a 2000 izusu and ac was working fine last year. Could some tell me about how much refrigerent i will need to recharge and have a diagram with instuctions on how to start or bypass compressor to charge with new refrigerent? thank you- ekimho 06-09-2008, 11:35 PM I too would like to know how to recharge my a/c... *crosses fingers* pharm_rodeo 06-10-2008, 04:44 AM IF you want to take the cheap way out, you can purchase a recharge kit at Walmart or any auto parts retailer. The kit should include a gauge which is not always accurate. Along the firewall you should see two light blue caps with a L and H. You recharge via the L (ow) side. Follow the directions on the package. Remember that you might have a leak in your system so recharging may not help. Also overcharging may kill your system leading to a huge repair bill. If you don't want to risk it then take your truck to a shop. I estimate the a/c service would run about $150. That's all I got.:licka: Cat Fuzz 06-10-2008, 09:56 AM You may or may not need refrigerant. If you do need it, you do have a leak. It's not a consumable item. If you never have a leak, you will never need to add more. It would be best to have someone properly trained in A/C repair look at and repair your system. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
