thinking of buying a 1995 civic plz tell me if its worth it
blake griffin
06-04-2008, 09:06 PM
ok this guy wants to trade for my 1994 eclipse gs turbo. the only thing thats wrong with my car is that the timing belt popped. Heres a list of what will be coming with the car because its currently not running but he has the parts to make it run.
D16 block bore .20 over, Notched, and the block was Decked
Polished and Knife edged Crank
Vitara pistions POLISHED
Complete D16 bottom end rebuild kit
Tuner toys H-Beam Rods Good for up to 500 HP
Tuner toys Vacuum manifold with all the fittings
2.5" v-band for turbo
DSM-550cc injectors
Arp head studs
KMS Block guard
New Water and Oil pump along with timing belt
ACL Race bearings
Zex 59300 VTEC cam
3 bar map sensor
Hopefully will have my buddies z6 head buy the time this is sold
Greddy E-manage Blue with everything you need to get it started
T3/T4 .57 trim oil feed turbo with all return lines and manual boost controller and blow off valve
F1 stage 4 clutch good for up to 400 hp
air fuel gauge and 3 gauge pod
IC charge pipe and clamps
Front Mount intercooler
Walboro 255 fuel pump
much more that I am forgetting
heres some pics of the car. the front end will be coming with the car
http://i6.photobucket.com/albums/y235/natalielover123/IMG_1909.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_1909.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_1911.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_1911.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_1912.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_1912.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_1915.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_1915.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_1917.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_1917.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_1918.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_1918.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2143.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2143.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2144.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2144.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2148.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2148.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2147.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2147.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2149.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2149.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2170.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2170.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2183.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2183.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2187.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2187.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2635.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2635.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2642.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2642.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2646.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2646.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2651.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2651.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2652.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2652.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2963.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2963.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2966.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2966.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2967.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2967.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2965.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2965.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2964.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2964.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2968.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2968.jpg)
http://i6.photobucket.com/albums/y235/natalielover123/IMG_2969.jpg (http://i6.photobucket.com/albums/y235/natalielover123/IMG_2969.jpg)
my question to you guys is is it worth it. i mean wut am i exactly getting myself into to make it run
DSM-550cc injectors
Arp head studs
KMS Block guard
ACL Race bearings
Zex 59300 VTEC cam
3 bar map sensor
CivicSpoon
06-05-2008, 12:52 AM
I wouldn't do it. Exterior looks beat and clearly needs body work & a paint job. The way the loom is off that engine harness looks like a potential nightmare. Maybe I'm not seeing things clearly, but the coolant passages (or whatever their technical name is) looks milky, like he blew a headgasket or somehow otherwise had oil mixing in his coolant. If that is what I'm seeing, there's no telling if it overheated to an extreme and something is really out of wack. He did bored it out, deck the block, and doesn't have the head; so to me that's an obvious sign of a previous issue. Don't get me wrong, the parts are good and all. I just wouldn't trade my car for someone else's unfinished/unassembled project car. And if your car runs (with a t-belt) and the body is in good condition, then it'd be a downgrade.
