1997 Blazer check engine codes
Google
Web AF
rednaxela_03
06-03-2008, 10:36 AM
I have a 1997 blazer 8th vin:w
i just got some codes pulled and they are as follows
p0740
p0753
p0758
p0785
p1361
p1860
:banghead:
I am also having a problem with the key getting stuck in the ignition
pls help if you can
thanx
maxwedge
06-03-2008, 10:57 AM
What are symptoms related to these codes?
blazee
06-03-2008, 12:26 PM
With those codes, I'd guess the symtoms are:
The transmission is in limp mode. (meaning that it shifts okay to start, but then doesn't downshift, giving you second or third gear starts, sluggish acceleration that feels as though the tranny is slipping, possible loss of overdrive)
Possible ocassional stalling.
Trouble starting at times.
Irratic dash light/ instrument panel gauge operation.
Based on your preliminary description, I'd *guess* that it is the ignition switch. Post back more detail or if you are experiencing the symtoms above, and I'll send you some info.
rednaxela_03
06-03-2008, 02:32 PM
some times it all works
check engine off and on but mostly on
it has been in fail safe mode for the most part no 1st gear no overdrive
the key will come out when it gets stuck if i play with it
i also had a dead battery yesterday no known reason why
ken_man_1
06-04-2008, 09:57 AM
Those p07** codes are all transmission codes. I'd look at the wiring harness and check for corrosion or being unplugged (or loose). Has there been a trans service done lately? If it's come and go type of thing, then something is loose electrically IMO. Just for sh*ts and g*ggles, check your fuses...
rednaxela_03
06-04-2008, 12:12 PM
I think i resolved the problem i replaced the ignition switch lets see how she does
thanks for the input it helped a good bit on where to start.:smile:
Google
Web AF
