Ignition keeps getting stuck
Google
Web AF
porrsher
06-01-2008, 07:59 PM
Anyone else having issues with the key turning? I have to sit and play with it to get it to turn. Is there a TSB on this?
Rimmer
06-03-2008, 09:03 PM
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
Try this site?
MT-2500
06-05-2008, 10:20 AM
What year and engine?
MT-2500
06-05-2008, 10:50 AM
tsb 06-02-35-016C date 7 10 02
certain years?
Pertains to removing lock cylinder and cleaning and lubing it with special gm lubercaint.
Fresno 126
06-18-2008, 12:49 AM
Amen, that is sound advise best I have heard in awhile.
If you could awnser a question , I will give a copy of the product when it comes out.
http://www.askdatabase.com/campaigns/?af=41989
srbetts
06-29-2008, 11:07 PM
I've had my Equinox for a week and all the sudden the key wont turn in the ignition. It takes about 10 min. sometimes to start the rig after a struggle. Seems the tumbler is stripped. Anyone else having this issue or know of an alternative to sending it back to the dealership with a fight to get it fixed?:banghead:
Fresno 126
06-30-2008, 12:10 AM
I am guessing you were unable to disassemble and lube the ingition lock assembly. if your car is under 60,000 miles or 5 years from being new, I can tell you what to say to get it repaired under warranty. If your car is older or above 60,000 miles there is no help less just paying for it to be repaired.Let me know and I will give you my phone number. :)
As a side note I am do a research project and could really use your input
porrsher
07-17-2008, 12:06 AM
2006 3.4L.
This situation has gotten worst, I went to the dealership and they took it apart and lubed it for the third time. Well its still doing it. I dont know what else to do, luckily we wont keep this vehicle much longer (fleet).
jmagerl
10-07-2008, 01:24 PM
Don't know how to describe it. When my key wont turn, I have to back off the steering wheel. Sometimes the steering wheel puts pressure on the lock mechanism and turning the wheel just a tad to relieve it is all it takes to turn the key
MT-2500
10-07-2008, 02:18 PM
That is normal operation.
Park it with wheels straight and wiggle the wheel a little to release pressure on the steering wheel lock up.
Good luck
tyland66
12-15-2009, 10:28 PM
We have a 07 Torrent that the key is sticking also. we have taken it to the dealership 3 or 4 times now and hopefully will have it fixed in a week. They were able to duplicate the problem and believe it to be the shifter or a solenoid, it kinda acts like a neutral safety switch which would only let you remove the key while it is park
Google
Web AF
