2004 Impala SS Starting ProblemMQC1079 05-30-2008, 10:58 AM I have a 2004 Impala SS With 38,000 miles. Last night I was at work and went to start my car and drive my half a mile home. It would not start, kept shtting down. Almost sounded like a lawn mower engine on slow idle then would shut down. As long as I gave it gas it would stay on, so I got halfway home when I had to stop to go around a corner it shut down so started again and applied gas all the way home. This morning woke up and went to start it and it started no problem, but I called dealership where I have a warranty anyways to let them know. The service dept. said to put the key to the on position for 20 minutes to let the car recongize the key. I did so and after doing that same thing that was happenening last night happened again. The dealership is sending a tow to pick it up, does anyone have any ideas what might be causing it? Thank You :banghead: maxwedge 05-30-2008, 04:14 PM Many things can cause this, let them handle what ever the issue is. MQC1079 05-31-2008, 10:58 AM Dealership called and told me they replaced the Mass Airflow Sensor, would that def. be causing issues I had? maxwedge 05-31-2008, 12:07 PM Yes it could be. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
