99 burb door locks/int lamps/keyless entry inop
chevylove1
05-28-2008, 06:28 PM
I was in the process of changing 4 door lock actuators in my 99 burb, when I realized my interior lamps had gone out. After realizing this I also noticed my keyless entry quit working as well. The drivers door lock switch will lock all of the doors and will unlock all of the doors except the drivers door. I removed the door lock relay and discovered that if you hold the drivers door lock button down in either position the interior lights come on and the keyless remote will work. Ive checked for good pwr and grounds at the keyless module and it still does this even if the keyless module is unplugged. (the pass switch will not unlock the drivers door either). HELP!:banghead:
clamfoot
06-08-2008, 06:32 PM
I also am having all of the symptoms that you have described on my 99 Burb!
I still am looking for help on this problem as of now. Please post something if you ever find out what is causing this!
