97 CRV check engne light ON
mikasa
05-27-2008, 09:29 PM
1997 CRV with check engine light. P-0441 EVAP Control System
Incorrect Purge Flow code in memory. Any advice in wich vay to look how to fix this will help.
tshih
09-24-2008, 12:56 PM
I think this means the gas filler cap is loose and the code needs to be cleared after tightening down on the fuel cap.
Airjer_
09-24-2008, 01:19 PM
this would be something other than a loose gas cap.
Loose gas caps will trigger the following three codes typically.
-P0442 Evaporative Emission Control System Leak Detected (small leak)
-P0455 Evaporative Emission Control System Leak Detected (gross leak)
-P0456 Evaporative Emissions System - Small leak detected
P0441 has to due with the purge flow.
