Page updated on 02-25-2018
1990 Royale 88 trunover won't start
L22
05-23-2008, 06:13 PM
I have 1990 Royale 88...3.8 etc... turns over won't start....Was running fine, no problems to speak of. Problem just came out of nowhere. Can anyone tell me where to start?
L22
05-23-2008, 07:57 PM
I have 1990 Royale 88...3.8 etc... turns over won't start....Was running fine, no problems to speak of. Problem just came out of nowhere. Can anyone tell me where to start?I would just like to add, that after sitting for a few hours, the car just started up as normal...Still curious as to what could cause this? Camshaft../..Crankshaft sensors?
maxwedge
05-23-2008, 08:19 PM
Only way to tell is to check for spark/injector pulse when this occurs again.
L22
05-26-2008, 09:56 AM
Thanks..I will check....I guess I can get a spark tester for the spark pulse..How can I check for injector pulse?
Thanks
maxwedge
05-26-2008, 12:20 PM
A noid lite, fairly cheap tool, plugs in the injector connector.
L22
05-30-2008, 01:10 PM
I'm still trying to find time to check for spark / injector pulse on this....
I will check tonight..
I wanted to add that I just noticed a substance(sealant or liquid) dripping out from between the ingnition coil and module. Will this require me to replace the coil / ignition module regardless of my problem?
Thanks
maxwedge
05-30-2008, 04:05 PM
Could be, pull off the module see where it is coming from.
L22
05-31-2008, 03:25 PM
Pulled off Ignition Module...A big mess, looks like a lot of melted plastic goop has flowed down to the bottom, underside.....covering the connectors on the bottom....Should I try to clean out of this stuff or do I need to replace the whole thing?
Also, finally checked for a spark while starting.....NO SPARK...While engine is hot
Thanks
maxwedge
05-31-2008, 05:22 PM
Replace it, not a used one either.
L22
05-31-2008, 07:29 PM
After a closer look at the back of the coil (after removal)....it looks like it's got a few cracks on it, near where the liquid is coming from....
L22
05-31-2008, 09:42 PM
Replaced coil....since it was the source of the leaking substance..It had a few cracks in it........Still wont' start while hot. Should I still replace Ignition module
L22
06-01-2008, 04:15 PM
Went ahead and replaced Ignition Module since it was a mess, kind of full of melted plastic...Still have the no start while hot problem.
So far, New:
Coil Pack
Ignition Module
From reviewing other post, the next thing I see would be the crank sensor?
Is there any way to test it?
thanks
Kia6666
06-16-2008, 04:04 PM
I Had the same problem with my 92 royale. After checking all the other things it finally came down to the cps (crank position sensor) It's all good now.
Kia6666
06-16-2008, 04:06 PM
if you can get it to a shop and they put it on a diagnostic the code should show up for the cps if that is the problem
L22
06-16-2008, 05:36 PM
yes...it was the crankshaft sensor....Had a tough time getting the harmonic balancer bolt off...Finally did, installed the new sensor..It's running great now
Thanks for your replies
