Vibration when turning right
Google
Web AF
JJohnson1388
05-23-2008, 12:32 PM
Last night I ran over a curb at walmart accidently. now whenever I make right turn there is this wierd noise from the right side going VVVVVVV. and the faster I go the higher pitch it gets. I checked my control, bushings, and tie rod and it looked fine? help?
rhandwor
05-25-2008, 08:39 PM
I would look at the universal joint to see if you bent it or tore off the rubber.
I not sure what your describing.
Scotty89
05-26-2008, 05:28 PM
Could be the wheel bearing on the right side, If the noise gets worse when you turn to the left, that might be the problem, and the nosie will usually get louder the faster u go.
Google
Web AF
