93 7.3idi need a turbo kit
Google
Web AF
kurtdeveau
05-15-2008, 09:46 PM
I have a 93 F-250 4x4 7.3 idi diesel and I would like to put a turdo on it. I would need the kit but does anyone know of one or anybody have such a kit for sale. Some things about the truck it has 260,000 miles and this winter I put a new injector pump and injectors in it and new glow plug controller and relay and glow plugs it gets about 15-17 mpg. Thanks for any help or suggestions anyone has, Kurt
FNA
05-16-2008, 10:59 AM
I'm not a diesel guy, but I would question the general idea of putting a blower on an engine with a quarter million miles on it.
mustangman02232
05-17-2008, 11:38 PM
do you have any other mods? turbos were optional in 94 so you could try and find one and pull it, or banks comes to mind
kurtdeveau
05-18-2008, 04:07 PM
banks has one but I think its around 2,000$ my brother in law thinks i shouldn't put a turbo on it because something else on the motor might go bad so i just don't know.
FNA
05-19-2008, 12:57 PM
"my brother in law thinks i shouldn't put a turbo on it because something else on the motor might go bad"
I wonder if he is influenced by the fact that it is 15 years old with a quarter-million miles on it?
Chevyman15004X4
05-28-2008, 06:10 AM
Slap a turbo on there like a banks sidewinder kit or ATS and don't worry about it. A new sidewinder kit from banks sells for under 3 grand but sometimes you can find great deals on ebay and at salvage yards. Lots of old trucks with turbos out there in the salvage yards. Just using the factory turbo doesn't give you that much more power if you put the one on from 93 to 94 1/2 ish idis.(unless your wanting to compensate for high altitude then they will help) Either way, Just keep your boost below 12 psi or you can blow your head gaskets because the factory head studs will not hold well. The banks kit is already setup for 12 psi max so you don't have to worry about it. If you want, you can upgrade your headstuds to ARP head studs but the kit is like $500 for them but you can increase the amout of boost also.
You will also want a pyro meter to measue your egts and make sure you don't over heat.
Usually the turbo will lower your egts with the fuel set correctly which can actually increase the life of your engine. My 93 7.3 IDI has 190,000 miles on it and Im not worried about it.
The banks turbo on mine help my fuel milage tromendesly while towing heavy loads and with no black smoke either. (although I didn't turn my fuel up that much)
Just remember, don't go over 12 psi. Some guys do but they are lucky.
Your showing to get fairly descent fuel milege. What gears are you running. I have 7.3 dually with 4.10 with a e40d and my truck weighs about 8,000 lbs and I get 16-17 mpg on the hwy at 65 mph. Im wanting to try 3:55 and see if that helps the mpg.
http://i267.photobucket.com/albums/ii319/chevyman15004x4/SUNP0004a.jpg
Google
Web AF
