90 Escort Water in Headlight Lens
frafreg
05-15-2008, 11:09 AM
I can see no visible signs of any cracks in the headlight lens yet, water is getting into the lens. The other day the water must have touched the halogen bulb when it was turned on at night and I found broken glass in the water at the bottom of the lens. I sucked out the water and the glass fragments with a shop vac but I would like to correct this problem so it does not happen again. Any suggestions on how to find the leak etc. would be much appreciated. Thank you very much
AzTumbleweed
05-15-2008, 12:47 PM
I've had this problem before and I drilled a small hole at the base of the headlight lense.
bugman742002
05-15-2008, 06:51 PM
i second the hole in the bottom of the lens. i also put a small on at the top as well so that if any water was left it would vent out the top while the lights were on.
