fuel pressure
Google
Web AF
ltacj5
05-10-2008, 08:38 PM
how do i remove the fuel pressure regulator from my 95 astro? it has the plenum. i cant even see the regulator from the front how is the best way to do it? dog box ?
brcidd
05-10-2008, 09:44 PM
You undress the top and front of the plenum and unbolt it and lift it off- do you have symptoms of a bad spider assembly- or a leak down?
ltacj5
05-10-2008, 10:09 PM
it wont start but it fires. sometimes runs for a few seconds. i pulled iac but still messed up. will start right away with a spray of eather but only runs rough for a few seconds. i dont know symptoms of spider or leak down. i do know the spider has been changed once awhile age. acording to pre owners records
old_master
05-12-2008, 06:27 PM
Check fuel pressure and leakdown before you take anything apart. It will tell what the problem is and save you a bunch of time and money. Key on, engine off, fuel pump running, fuel pressure must be 60psi to 66psi. Must remain above 55psi for 3 to 5 minutes after the pump shuts off. Post your results.
Google
Web AF
