ENGINE SWAP! 2005 Equinox LT 3.4 with 2008 Impala 3.9!! Will it work??octaneautos 05-10-2008, 11:45 AM Hey everyone! Happy Friday! I'm tinkering with a project this coming weekend, and wondering if any of you folks might have tried and failed, or has some advice... I am preparing to pull a 3.4 liter out of a 2005 equinox lt and replace it with a 3.9 liter from an 08 Impala. Will i have problems? Will the tranny mate up ok? Any reason why i shouldn't do it?? This could be fun, or it could be a total pain in the ace! Any constructive input from you GM guys would be much appreciated! Cheers! MT-2500 05-17-2008, 01:21 PM I would stay with the same engine. You are going to run into a bunch of technical and legal problem and plain headaches. MT octaneautos 05-19-2008, 03:52 PM I have a brand new engine sitting on my shop floor, looks like everything will work. If you were in my situation, you'd want to try it too. Why wouldn't it work? MT-2500 05-19-2008, 06:58 PM I have a brand new engine sitting on my shop floor, looks like everything will work. If you were in my situation, you'd want to try it too. Why wouldn't it work? No way would I touch someting like that.:nono: 3.4 to a 3.9 may not fit or work out and a bunch of legal stuff on swaping motor sizes. But if you want to have at it good luck. MT octaneautos 05-19-2008, 07:32 PM What's the legal end have to do with it? What are you credentials? have you any specific reasons why it might not work. You may be talking me out of this. We looked and on other forums people said (and i confirmed) the block, bell housing, and sensor bolts are all the same place. I of course will change the intake to the 3.4 intake and plenum so's not to mess up the PCM. Tell me why it can't be done?? MT-2500 05-19-2008, 08:01 PM What's the legal end have to do with it? What are you credentials? have you any specific reasons why it might not work. You may be talking me out of this. We looked and on other forums people said (and i confirmed) the block, bell housing, and sensor bolts are all the same place. I of course will change the intake to the 3.4 intake and plenum so's not to mess up the PCM. Tell me why it can't be done?? I did not say it could not be done. :meant: To stay legal. Insurance and state title will have to be changed for a different size engine swap. And may have to be state inspected and retitled as a rebuilt car title. Check you state title and regestion and lisence rules and regulations. Also If you run it on a federal funded highway. http://www.epa.gov/air/caa/caa203.txt Sec. 203. (a) The following acts and the causing thereof are prohibited- (1) in the case of a manufacturer of new motor vehicles or new motor vehicle engines for distribution in commerce, the sale, or the offering for sale, or the introduction, or delivery for introduction, into commerce, or (in the case of any person, except as provided by regulation of the Adminis- trator), the importation into the United States, of any new motor vehicle or new motor vehicle engine, manufactured after the effective date of regulations under this part which are applicable to such vehicle or engine unless such vehicle or engine is covered by a certificate of conformity issued (and in effect) under regulations prescribed under this part or part C in the case of clean-fuel vehicles (except as provided in subsection (b)); (2)(A) for any person to fail or refuse to permit access to or copying of records or to fail to make reports or provide information required under section 208; (B) for any person to fail or refuse to permit entry, testing or inspection authorized under section 206(c) or section 208; (C) for any person to fail or refuse to perform tests, or have tests performed as required under section 208; (D) for any manufacturer to fail to make information available as provided by regulation under section 202(m)(5); (3)(A) for any person to remove or render inoperative any device or element of design installed on or in a motor vehicle or motor vehicle engine in compliance with regula- tions under this title prior to its sale and delivery to the ultimate purchaser, or for any person knowingly to remove or render inoperative any such device or element of design after such sale and delivery to the ultimate purchaser; or (B) for any person to manufacture or sell, or offer to sell, or install, any part or component intended for use with, or as part of, any motor vehicle or motor vehicle engine, where a principal effect of the part or component is to bypass, defeat, or render inoperative any device or element of design installed on or in a motor vehicle or motor vehicle engine in compliance with regulations under this title, and where the person knows or should know that such part or component is being offered for sale or installed for such use or put to such use; or (4) for any manufacturer of a new motor vehicle or new motor vehicle engine subject to standards prescribed under section 202 or Part C- (A) to sell or lease any such vehicle or engine unless such manufacturer has complied with (i) the requirements of section 207 (a) and (b) with respect to such vehicle or engine, and unless a label or tag is affixed to such vehicle or engine in accordance with section 207(c)(3), or (ii) the corresponding requirements of part C in the case of clean fuel vehicles unless the manufacturer has complied with the corresponding requirements of part C (B) to fail or refuse to comply with the requirements of section 207 (c) or (e), or the corresponding requirements of part C in the case of clean fuel vehicles (C) except as provided in subsection (c)(3) of section 207 and the corresponding requirements of part C in the case of clean fuel vehicles, to provide directly or indirectly in any communication to the ultimate purchaser or any subsequent purchaser that the coverage of any warranty under this Act is conditioned upon use of any part, component, or system manufactured by such manufacturer or any person acting for such manufacturer or under his control, or conditioned upon service performed by any such person, or (D) to fail or refuse to comply with the terms and conditions of the warranty under section 207 (a) or (b) or the corresponding requirements of part C in the case of clean fuel vehicles with respect to any vehicle; or (5) for any person to violate section 218, 219, or part C of this title or any regulations under section 218, 219, or part C. No action with respect to any element of design referred to in paragraph (3) (including any adjustment or alteration of such element) shall be treated as a prohibited act under such paragraph (3) if such action is in accordance with section 215. Nothing in paragraph (3) shall be construed to require the use ofmanufacturer parts in maintaining or repairing any motor vehicle or motor vehicle engine. For the purposes of the preceding sentence, the term "manufacturer parts" means, with respect to a motor vehicle engine, parts produced or sold by the manufacturer of the motor vehicle or motor vehicle engine. No action with respect to any device or element of design referred to in paragraph (3) shall be treated as a prohibited act under that paragraph if (i) the action is for the purpose of repair or replacement of the device or element, or is a necessary and temporary procedure to repair or replace any other item and the device or element is replaced upon completion of the procedure, and (ii) such action thereafter results in the proper functioning of the device or element referred to in paragraph (3). No action with respect to any device or element of design referred to in paragraph (3) shall be treated as a prohibited act under that paragraph if the action is for the purpose of a conversion of a motor vehicle for use of a clean alternative fuel (as defined in this title) and if such vehicle complies with the applicable standard under section 202 when operating on such fuel, and if in the case of a clean alternative fuel vehicle (as defined by rule by the Administrator), the device or element is replaced upon completion of the conversion procedure and such action results in proper functioning of the device or element when the motor vehicle operates on conventional fuel. (b)(1) The Administrator may exempt any new motor vehicle or new motor vehicle engine from subsection (a), upon such terms and conditions as he may find necessary for the purpose of research, investigations, studies, demonstrations, or training, or for reasons of national security. (2) A new motor vehicle or new motor vehicle engine offered for importation or imported by any person in violation of subsection (a) shall be refused admission into the United States, but the Secretary of the Treasury and the Administrator may, by joint regulation, provide for deferring final determination as to admission and authorizing the delivery of such a motor vehicle or engine offered for import to the owner or consignee thereof upon such terms and conditions (including the furnishing of a bond) as may appear to them appropriate to insure that any such motor vehicle or engine will be brought into conformity with the standards, requirements, and limitations applicable to it under this part. The Secretary of the Treasury shall, if a motor vehicle or engine is finally refused admission under this paragraph, cause disposition thereof in accordance with the customs laws unless it is exported, under regulations prescribed by such Secretary, within ninety days of the date of notice of such refusal or such additional time as may be permitted pursuant to such regulations, except that disposition in accordance with the customs laws may not be made in such manner as may result, directly or indirectly, in the sale, to the ultimate consumer, of a new motor vehicle or new motor vehicle engine that fails to comply with applicable standards of the Administrator under this part. (3) A new motor vehicle or new motor vehicle engine intended solely for export, and so labeled or tagged on the outside of the container and on the vehicle or engine itself, shall be subject to the provisions of subsection (a), except that if the country which is to receive such vehicle or engine has emission standards which differ from the standards prescribed under section 202, then such vehicle or engine shall comply with the standards of such country which is to receive such vehicle or engine. [42 U.S.C. 7522] http://www.epa.gov/air/caa/caa205.txt SEC. 205. CIVIL PENALTIES. (a) Violations.- Any person who violates sections 203(a)(1), 203(a)(4), or 203(a)(5) or any manufacturer or dealer who violates section 203(a)(3)(A) shall be subject to a civil penalty of not more than $25,000. Any person otherthan a manufacturer or dealer who violates section 203(a)(3)(A) or any person who violates section 203(a)(3)(B) shall be subject to a civil penalty of not more than $2,500. Any such violation with respect to paragraph (1),(3)(A), or (4) of section 203(a) shall constitute a separate offense with respect to each motor vehicle or motor vehicle engine. Any such violation with respect to section 203(a)(3)(B) shall constitute a separate offense with respect to each part or component. Any person who violates section 203(a)(2) shall be subject to a civil penalty of not more than $25,000 per day of violation. (b) Civil Actions.- The Administrator may commence a civil action to assess and recover any civil penalty under subsection (a) of this section, section 211(d), or section 213(d). Any action under this subsection may be brought in the district court of the United States for the district in which the violation is alleged to have occurred or in which the defendant resides or has the Administrator's principal place of business, and the court shall have jurisdiction to assess a civil penalty. In determining the amount of any civil penalty to be assessed under this subsection, the court shall take into account the gravity of the violation, the economic benefit or savings (if any) resulting from the violation, the size of the violator's business, the violator's history of compliance with this title, action taken to remedy the violation, the effect of the penalty on the violator's ability to continue in business, and such other matters as justice may require. In any such action, subpoenas for witnesses who are required to attend a district court in any district may run into any other district. (c) Administrative Assessment of Certain Penalties.- (1) Administrative penalty authority.- In lieu of commencing a civil action under subsection (b), the Administrator may assess any civil penalty prescribed in subsection (a) of this section, section 211(d), or section 213(d), except that the maximum amount of penalty sought against each violator in a penalty assessment proceeding shall not exceed $200,000, unless the Administrator and the Attorney General jointly determine that a matter involving a larger penalty amount is appropriate for administrative penalty assessment. Any such determination by the Administrator and the Attorney General shall not be subject to judicial review. Assessment of a civil penalty under this subsection shall be by an order made on the record after opportunity for a hearing in accordance with sections 554 and 556 of title 5 of the United States Code. The Administrator shall issue reasonable rules for discovery and other procedures for hearings under this paragraph. Before issuing such an order, the Administrator shall give written notice to the person to be assessed an administrative penalty of the Administrator's proposal to issue such order and provide such person an opportunity to request such a hearing on the order, within 30 days of the date the notice is received by such person. The Administrator may compromise, or remit, with or without conditions, any administrative penalty which may be imposed under this section. (2) Determining amount.- In determining the amount of any civil penalty assessed under this subsection, the Administrator shall take into account the gravity of the violation, the economic benefit or savings (if any) resulting from the violation, the size of the violator's business, the violator's history of compliance with this title, action taken to remedy the violation, the effect of the penalty on the violator's ability to continue in business, and such other matters as justice may require. (3) Effect of administrator's action.- (A) Action by the Administrator under this subsection shall not affect or limit the Administrator's authority to enforce any provision of this Act; except that any violation, (i) with respect to which the Administrator has commenced and is diligently prosecuting an action under this subsection, or (ii) for which the Administrator has issued a final order not subject to further judicial review and the violator has paid a penalty assessment under this subsection, shall not be the subject of civil penalty action under subsection (b). (B) No action by the Administrator under this subsection shall affect any person's obligation to comply with any section of this Act. (4) Finality of order.- An order issued under this subsection shall become final 30 days after its issuance unless a petition for judicial review is filed under paragraph (5). (5) Judicial review.- Any person against whom a civil penalty is assessed in accordance with this subsection may seek review of the assessment in the United States District Court for the District of Columbia, or for the district in which the violation is alleged to have occurred, in which such person resides, or where such person's principal place of business is located, within the 30-day period beginning on the date a civil penalty order is issued. Such person shall simultaneously send a copy of the filing by certified mail to the Administrator and the Attorney General. The Administrator shall file in the court a certified copy, or certified index, as appropriate, of the record on which the order was issued within 30 days. The court shall not set aside or remand any order issued in accordance with the requirements of this subsection unless there is not substantial evidence in the record, taken as a whole, to support the finding of a violation or unless the Administrator's assessment of the penalty constitutes an abuse of discretion, and the court shall not impose additional civil penalties unless the Administrator's assessment of the penalty constitutes an abuse of discretion. In any proceedings, the United States may seek to recover civil penalties assessed under this section. (6) Collection.- If any person fails to pay an assessment of a civil penalty imposed by the Administrator as provided in this subsection- (A) after the order making the assessment has become final, or (B) after a court in an action brought under paragraph (5) has entered a final judgment in favor of the Administrator, the Administrator shall request the Attorney General to bring a civil action in an appropriate district court to recover the amount assessed (plus interest at rates established pursuant to section 6621(a)(2) of the Internal Revenue Code of 1986 from the date of the final order or the date of the final judgment, as the case may be). In such an action, the validity, amount, and appropriateness of the penalty shall not be subject to review. Any person who fails to pay on a timely basis the amount of an assessment of a civil penalty as described in the first sentence of this paragraph shall be required to pay, in addition to that amount and interest, the United States' enforcement expenses, including attorneys fees and costs for collection proceedings, and a quarterly nonpayment penalty for each quarter during which such failure to pay persists. The nonpayment penalty shall be in an amount equal to 10 percent of the aggregate amount of that person's penalties and nonpayment penalties which are unpaid as of the beginning of such quarter. [42 U.S.C. 7524] 05blkequinox 01-12-2009, 05:21 PM I think it can be done. Im no expert by far..... If you have done the research and think it will mount up right then go for it. Of course as you know you will need a new harness and all the small stuff but for the most part It should be able to be done. I haven't looked into it but I believe you said you have. As far as the legal part of it. It is NOT elligal to swap engines to a bigger size. As long as you still have the Emmision levels under control and the CPU is programed correctly your emmision sould stay fine.. I hat to throw peoples name it to but Shorod is a very good person to get advice from. Every problem I have had he has had some really good solutions..Maybe he will see this and add a post.,.... drdisque 01-14-2009, 11:56 PM The thing I'd be concerned about is that the two engines are from two different families and you might encounter some incompatibility issues. I'd be much more comfortable swapping the 3.9 into a car that came with the 3.5 rather than the 3.4 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
