size of the bolts that hold the fuel tankleegaddis32 05-03-2008, 03:30 PM any one know the sizes of the bolts that holds the fuel tank straps on a 99 astro want to make sure have everything i need to drop the tank thanks in advance brcidd 05-03-2008, 07:10 PM Why not re-use the old ones? Or take them in to get the same- I would gues M-10x20mm but I could be wrong without the okd ones in hand... leegaddis32 05-03-2008, 08:32 PM ment what size socket sorry about that brcidd 05-03-2008, 09:17 PM I think they are 15mm socket heads.... Blue Bowtie 05-04-2008, 12:06 AM Don't forget the penetrating oil for removal, and anti-seize for assembly. You'll also need a 5/16" or 8mm socket for the clamps on the fill and overflow hoses, a T20 Torx for the screws in the fuel filler door, and a good pair of chain nosed pliers and small Chan-Nel-Locks to remove the speed nuts holding the wire harness to the left side of the tank. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
