1999 LHS fuel filter location how to change?donniegs 04-29-2008, 05:45 AM Can anyone tell me where the fuel filter is for a 1999 LHS? How do you change it? Thanks!! Also I bought gas from a station and it started running rough in a few days. This only happens to the LHS. I put gas in my old 1992 F-150 from the same station just a half hour earlier and it has no problems. Is this just a LHS thing? It just seams it is more sensitive to gas that has a small amount of contamination. Thanks again for any help here. kam300m 05-01-2008, 02:34 AM I do know that you have to put 89 octane in those and sometimes they will have a slight knock due to the gas. And with the fuel filter, it is in the gas tank I am pretty sure that in the trunk under the fabric there is a plate that can be removed to get at it, so you don't have to take out the whole tank. donniegs 05-01-2008, 05:07 AM Thanks so much for the info. I'll check this out. As soon as I find out, I will post an answer here so anyone else will know also. donniegs 05-04-2008, 08:24 AM Okay, this is what I found out. First, you cannot get to the filter from under the rear seat. It is best to get a shop manual, or Haynes Manual, or get a pro to do this job because you will have to remove the tank to get to it all. Really sucks!!!! Fortunantly after some more investigation I found that I had a bad sprark plug. Replaced it and it runs great!! The plugs were not that old, but I guese something happened when I installed them or it was a bad one off the line. Not sure. Just glad I got it running right again. Thanks for answers. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
