oil leak for 2000 regal
jerry1967
04-28-2008, 11:57 AM
I think my oil pan is leaking. Has any body ever changed their oil pan on a 2000 regal? Is it very hard ? What kind of tools do I need to do this job?
BNaylor
04-30-2008, 08:37 AM
The hardest part is getting clearance to get to the oil pan bolts towards the front of the engine and removing the oil pan to replace the gasket. The engine/tranny subframe is in the way. You have to hold the engine/tranny with a hoist and then drop down the subframe assembly.
For now make sure none of the bolts are loose and check tightness/torque of bolts with a torque wrench. 89 in-lbs.
jerry1967
05-11-2008, 08:13 AM
thank you
thank you
