What does it take to convert to a L82 350?
Google
Web AF
Bob's75Vettebaby
04-14-2008, 12:35 AM
To make my 75 into a L82 vette what do I change????:naughty:
stepho
04-26-2008, 09:53 AM
You need to change the heads, intake, and I believe the carb also has to be changed, but I'm not 100% on that.
thrasher
04-26-2008, 04:30 PM
It takes a lot more than that. The L82 uses 4 bolt mains and a forged crank, in addition to a different cam and higher compression pistons. Even then, the L82 is a dog compared to more modern setups, like a vortec kit. With the money you spent converting to an L82 setup, you would be far better off rebuilding and going to a higher compression setup or even getting a crate engine.:2cents:
comp
04-28-2008, 01:01 PM
the Vortec heads work pretty good with a L-82 spec cam
Blue Bowtie
04-28-2008, 10:35 PM
The L82 cam is really mild. The one I pulled from a stock L82 was the old '929 cam - GM 3896929 .390"/.410" 196º/205º 112º LSA. It went to the scrap bin in favor of a slightly less mild aftermarket cam - .443" /.465" - 214º/224º - 112º LSA, and performed much better with the '416 heads which replaced the original stock smog-dog castings.
http://72.19.213.157/files/C-3CamRemoval.jpg
Not to hurt anyone's feelings, but the L82 was about on par with a 1984 Ford Fiesta for power. If you're really going to spend any money on it, take the previous advice and start with a later (roller) block and create something worthy of a Y-Car.
comp
04-29-2008, 05:36 AM
i agree it is a mild cam,,,last one i got was ,,like 34 dollar TRW replacement ,,he didn't even plan on running headers
Google
Web AF
