1993 s-10 missing real badcadillac_bn 04-11-2008, 12:42 AM i have a 1993 s-10 with a 2.5 4 cylinder it is missing real bad i can pull the 2 middle plug wires off and it doesn't change anything so pretty much i'm only running on 2 cylinders i put new wires,plugs,cap,rotor,air filter,breather filter and pcv valve and that did not change anything but i am getting spark to all cylinders i've checked that i've also tried turning the distributer and that didn't help either it ran verry good up untill that point i just cant figure it out if anyone has any sugestions please let me know i'll try anything to get her goin again!!!!!! please help me!!!!:banghead: DAB77 04-11-2008, 09:26 PM first thing you need to do is a compression test on all cylinders. if you don't have a compression gauge you can rent one pretty cheap at most parts stores. if you have good compression and you have spark at all the cylinders and assuming you have 4 separate injectors, switch the injectors and see if your miss moves with them.try that and post what you have. cadillac_bn 04-12-2008, 04:38 PM hey thanks for the reply i'm gonna do a compresion test on it today or tomorow but its carberated so i don't have any injectors. any other sugestions before i do a compresion test on it? thanks Chris Stewart 04-12-2008, 08:38 PM It has a Throttle Body Fuel Injection...looks like a carburetor though. I had the same motor in a 1986 Cutlass Ciera....it's the Pontiac 151cu.in. Iron Duke motor, tough piece. You might look at the sparkplugs on the middle cylinders to see if they're fouled or not. cadillac_bn 04-13-2008, 10:30 PM i just put new plugs in it and drove it bout 3 days and the 2 inside ones are realy carboned up but the 2 outside pones are burning pretty good someone told me that he thinks my valves are bad and how do i switch my injectors? Chris Stewart 04-13-2008, 11:28 PM You have 1 injector body and they're pretty reliable. Is the air filter oily? cadillac_bn 04-14-2008, 12:04 PM it was but i replaced that the breather filter and the pcv valve and the air filter was only about 8 months old vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
