Knock sensor bad?SnipesXxX 04-09-2008, 05:07 PM I have a 2000 GA SE with a 2.4 and 160k miles. I was looking in a repair manual and I did not know anything about a knock sensor. I am wondering if maybe it ain't bad because when the car is under load(A/C, heat, ect) the engine makes a noticeable knocking sound. Is this a normal sound for these Quad 4's or could the sensor be bad? xeroinfinity 04-10-2008, 12:15 AM YOu would need to have it scanned to find out if the sensors bad. Your knocking could be something else..... :eek: SnipesXxX 04-10-2008, 02:06 PM if it wasn't working would it throw a check engine light? xeroinfinity 04-10-2008, 04:04 PM Not always. If was working within the threshold of the sensro perameters it might not, if was totaly broken or has a bad circuit then it would throw a DTC. Though, if its pounding/knocking like a hammer beating your engine block... its probly not the sensor. Go get it scanned ! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
