1999 grand prix gtp no power
Google
Web AF
n2racingcars
04-09-2008, 12:14 PM
When I am on level highway and at normal speed I do not see a problem. When I approach a grade and speed up just a little the boost maxs out and still has no power and then if I really give it the gas it starts to ping real bad and will die in the next 10 seconds. I will turn off the key and wait 5 to 10 seconds and it will refire. I changed the fuel filter and no help. It has 125,000 mile on it.
BNaylor
04-09-2008, 01:10 PM
What brand and octane gasoline are you using?
n2racingcars
04-09-2008, 01:33 PM
Regular gas. The lowest octane That is what I have always ran.
BNaylor
04-09-2008, 01:39 PM
Regular? :shakehead You should be using 91 octane premium unleaded or better in a GTP. See link below as to why.
Click here (http://www.automotiveforums.com/vbulletin/showthread.php?t=664475)
daejuanj
04-09-2008, 02:14 PM
Just curious, doesn't the inside of the gas tank cover say Premium fuel only? I know mines does.
BNaylor
04-09-2008, 02:17 PM
Yes and so does the owner's manual.
maney8295
04-13-2008, 07:08 PM
Get a Honda Civic.
grandprixgtx00
04-13-2008, 09:43 PM
Get a Honda Civic.
:thumbsdow
BNaylor
04-13-2008, 11:21 PM
Get a Honda Civic.
:thumbsdow
:uhoh:..............:lol:
I could be wrong but I think he was joking or said that facetiously. In other words if you are looking for economy like running regular unleaded gas since Honda Civics typically work fine on it but on L67s different issue.
We'll allow some Honda bashing to a point. However, just stay out of the various AF Honda forums or you'll most likely be very sorry. Frick'ng hornet's nest.
BTW - I don't drive Hondas I ride them. :grinyes:
grandprixgtx00
04-13-2008, 11:24 PM
haha, yeah...I'd hope so!
:lol: same here! got a honda rubicon sittin in the garage!
daejuanj
04-15-2008, 03:17 PM
I still don't see what the big deal is. Here in Chicago were gas prices are fairly high on average in the USA. The price difference between low-grade and premium gasoline is around $0.20, sometimes $0.30. Since I drive a lot, I always just fill up from about 1/8th a gallon of gas in the tank. Say less than 15 gallons to fill.
In total, I would save around $3.00 if I were to use regular gas (87 octane). I fill up once a week, so about $12 a month.
I spend more on fast food. The price difference isn't a big deal as people make it.
jessiebighamKC
04-16-2008, 06:22 AM
Yeah I never put unleaded fuel in it! I mean for the price Id rather put the preium in it! its better than having to replace the motor. I have put unleaded in my car once I first got it and I only did that once and I could tell the difference and even burnt my plugs using unleaded. And the Honda comment! They are better on gas but would never own one! Isnt this a grand prix forum? LOL
BNaylor
04-16-2008, 06:41 AM
:confused:
What country are you living in? All retail pump gasoline sold in this country is unleaded. The Clean Air Act of 1996 banned all remaining leaded fuels for use in on-road vehicles. However, it is still available but for off-road (race cars), aircraft and marine use. But your point on using premium unleaded is well taken.
jessiebighamKC
04-16-2008, 07:02 AM
Ok point taken! Maybe I should of phrased it differently! Higher Octane! I know all gas at gas stations are unleaded but I was talking about the higher octane(Premium Unleaded Gas)
n2racingcars
04-16-2008, 10:21 AM
thanks for all the help. It was a clogged cat converter
BNaylor
04-16-2008, 12:17 PM
Thanks for the feedback.
But what caused the CAT converter to fail prematurely? We have members with '99 and under GTPs that have well over 125K miles and still have the original CAT converter. How are you monitoring knock retard (KR)? I hope you're not still planning on running regular unleaded gas. :grinno:
IMO running regular unleaded was probably a cause. Running fuel that is too low of an octane causes detonation or pre-ignition. Also, it causes carbon buildup. When detonation occurs combustion chamber temperatures increase to include what goes out the exhaust (out gases). With detonation the air/fuel mix ignites prematurely. Any unburned fuel goes out the exhaust right to the CAT converter. This unburned fuel will ignite in the catalytic converter causing the converter to run hotter. This shortens the catalytic converter's life. :eek:
n2racingcars
04-16-2008, 02:08 PM
I am sure it was the gas. I will use premium from how on.
Google
Web AF
