Premium Unleaded Only?
Google
Web AF
FullyAvenged
04-08-2008, 10:09 PM
Just recently got the 99 GTP. I know it calls for the Premium Fuel, Can I possibly do Premium every other time I fill up or should it be everytime I fill up.
grandprixgtx00
04-08-2008, 10:13 PM
well...technically, you should never run lower than 91 octane in your GTP, but i know people that put mid-grade in their GTP if they know they're not going to be running any boost I.E just cruising down the highway...not passing.
personally i only run Premium, that way i know I'm not running the rist of KR
BNaylor
04-09-2008, 08:01 AM
:1:
If saving a few cents per gallon is that important by using for example mid-grade which I have done on my Regal GS and what appears to be a reasonable option is to use one range colder spark plugs. However, I'd be cautious about any pedal to the metal or any driving conditions where the engine is under a heavy load. Definitely no regular unleaded. :grinno:
GTP Dad
04-09-2008, 08:05 AM
:iagree: Stick with the 93 octane. You may save 10 cents per gallon using the lower octane but you may spend $4000 for a new engine if happen to go wot one too many times.
BNaylor
04-09-2008, 08:35 AM
93 would be nice if you can get it Lynn but the recommendation from GM is 91 octane or better. Most of us can't get 93 octane like found at the Sunoco gas stations back in the Northeast.
daejuanj
04-09-2008, 09:21 AM
Where I live at I usually find 93 octane. I believe I I filled up with 92 one time, but I've never seen a gas station with 91.
BNaylor
04-09-2008, 09:58 AM
91 octane is very common in the Western/Rocky Mountain states. That is why GM specifies at least 91 octane. Maybe seeing is believing. :wink: Reason is the higher altitudes so the oil companies can drop a few points on octane. Also, notice the lower octane level on mid-grade and regular unleaded.
BTW - I'm at 4000 feet altitude.
http://i5.photobucket.com/albums/y186/lizzywiz/DSC09833-1.jpg
Top Tier Chevron
HotZ28
04-09-2008, 10:00 AM
Fortunately in my area and most of the South East, we still have the choice between 93, 89 & 87 Octane. I usually try to fill-up when the fuel gage reaches ½ tank. I sometimes alternate between 93 & 89 @ fill-up, which renders the 91 suggested. Never had a KR or misfire even under heavy load & pedal to the metal acceleration! :shakehead BTW, this is for the Ultra Series II VIN 1 RPO L67, not the Z, only 105 in that one. I forgot to mention, we have several stations near Road Atlanta, that have pumps available with 105 octane for anyone who wants to pay the price!
BNaylor
04-09-2008, 10:14 AM
I use VP Racing 108 unleaded when I'm at the strip. KR will be minimal or nil if you are stock. Boost mods is a different issue. I run a 3.0 SC pulley on my GTP.
However, the pulley system is modular so I can switch back to the 3.25" or higher if necessary.
daejuanj
04-09-2008, 02:34 PM
Of course BNaylor, I believed you. I should have clarified that I was just referring to where live in Chicago. I have yet to see 91 octane, it's usually 93.
BTW, Our gasoline is usually.
87 - 89 - 93
richtazz
04-09-2008, 04:12 PM
Sunoco has tried to push that 86 octane here in Michigan, but cars run like dog-doody on it at our altitude so they stopped selling it here.
FullyAvenged
04-09-2008, 04:36 PM
Yup I live in MI also and what I normally see is 87-89-93. I have been putting nothing but 93 in it but I was just wondering if it really made a differance.
BNaylor
04-09-2008, 05:13 PM
You'll never really know for sure until you run a KR check with a scan tool capable of reading out accurate KR at all driving conditions since KR will vary at times even if you are stock. But here is some anecdotal info that is very recent and I could pull up a bunch of old posts over the years that are worse going as far as blown engines. This guy is running regular unleaded brand unknown. :eek:
http://www.automotiveforums.com/vbulletin/showthread.php?t=898029
GTP Dad
04-10-2008, 07:54 AM
93 is quite common in PA with some stations selling 92 octane as their top fuel grade. I have seen some 94 octane at certain Sunoco stations but it isn't common. 91 is sufficient but the owners manual on my 97 specifically stated premium fuel of at least 93 octane. Obviously GM didn't intend for the car to last long enough to see another octane reduction. Oh well, one day we may have a hard time finding 87 Octane if things don't change!
By the way Bob how much is the 108 racing gas per gallon?
BNaylor
04-10-2008, 09:30 AM
What page was that on Lynn? That data was quickly revised by GM and superceded 10 years ago. On subsequent owner's manuals it clearly states 91 octane or higher. For example the '99 owner's manual in which the OP has 91 octane is listed.
It varies depending on which specific formula you decide to get based on your application. StreetBlaze, C10, Motorsport XXX, etc. It was $5.50 per gallon with a minimum bucket size of 5 gallons. And the octane specified is more technical spec wise. There is Motor Octane, R+M/2 Octane and Research Octane. For example on Motorsport 109 unleaded:
• Motor Octane: 101
• R+M/2: 105
• Research Octane: 109
Google
Web AF
