Drain and fillSnipesXxX 04-08-2008, 01:16 PM Do I put the 50/50 stuff back in or full dex cool? This is a 2000 GA SE with 2.4L Dex Cool. I want to put Dex Cool back in it. J-Ri 04-08-2008, 05:37 PM The final mix should be 50/50 (or whatever you need for freeze protection). If you just drained and filled, add 50/50 to it. If you flushed the block with water, add 1/2 the capacity of straight coolant, then top it off with water. SnipesXxX 04-09-2008, 12:27 AM k Thx BTW does anyone know right off how many gallons the 2000 GA SE needs with a Quad 4? skibum1111 04-09-2008, 06:26 PM If it was entirely empty it takes about 3 gallons total. Fill it with the appropriate mix and bleed the system. The quad motors can take a while to bleed, mine used to take me about 45 minutes for the tstat to open and close several times and it will swallow a bit more coolant during the process. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
