10 Bolt Housings?iroc343 04-08-2008, 10:11 AM I have an 89 camaro with a 10 bolt and disc brakes. I found a 10 bolt from an 87 firebird with 4.10's, only problem is it has drum brakes. Can I bolt the backing plates and disk brakes from my car directly to the housing from the firebird? Are the housing ends the same? ANGER_TRAIN 05-04-2008, 06:36 AM if you want that rear end for the gears, it would be a lot easier to buy a new ring and pinion and install that instead of swapping our rears. good luck! Morley 05-04-2008, 05:08 PM All you should need from the 87 is the carrier unit (it has the gears in it). Swapping out the entire rear end is a lot of work. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
