Is mine inferior to a GTP???
Google
Web AF
maney8295
04-08-2008, 03:21 AM
So I recently traded in my black fully loaded '92 olds toronado trofeo for a black 2000 grand prix gt coupe, 80k w/ leather(got a fair deal). Now I'm thinking maybe I should've waited until I found one just like it but a fully loaded mint GTP. Should i be kicking myself over this or should I just be happy with the plain ol gt? Also, is there a big difference between a regular gt like mine and stock GTP with no mods?? Since i heard the GTP comes with a much better trans and I already had to have the pressure control solenid replaced I'm wondering about all this now. Should I keep the one I have or hurry up and sell it so I can still get a mint GTP coupe w/ low miles??? Advice anyone?
GTP Dad
04-08-2008, 07:58 AM
There is nothing wrong with a GT model Grand Prix. The 3.8 normally aspirated engine does have less power than the GTP but it is a reliable engine.
One problem you may run into are leaking lower intake manifold gaskets but GM corrected most of the issues with these gaskets in a prior year. As for the transmission the 4t65E HD transmission isn't a better transmission it is just a beafier transmission to handle the additional power. The PCS problem can hit the GTP transmission just as easily as the one in your car. I don't think you went wrong with your purchase and you shouldn't be disappointed with it.
kapp0
04-08-2008, 05:43 PM
One advantage to the Gt is that it takes any gasoline instead of premium for the GTP. I bought a GTP and kind of kicking myself for not just getting a GT.
drob99
04-10-2008, 11:16 AM
I have a 2002 GP GT and its great. My car is already fast and i cant imagine how fast it would be with a supercharger. I got a GT because u can put regular gas in it. not like the GTP. and its better than the SE model.
daejuanj
04-10-2008, 11:37 AM
I thought putting Premium gas would be a problem when I started filling up. But the price difference is probably 2 or 3 dollars, well worth it though.
fst100
04-10-2008, 11:43 AM
the GT/L36 has a shorter gearing at 3.29s and has a better go from a stop compared to a GTP with 2.93 gears. for performance parts you have options depending on how big your wallet is. u can do your research and go from there. here are some ways to make your GT quick:
-a top swap, swapping the items from the GT with GTP such as the heads, lower intake manifold, intake and a few other parts
-bolt-on mods such a higher ratio rockers
-an aftermarket cam
-an aftermarket cam and a CSC(centrifugal supercharger)
-turbo
again, do your research and you'll be fine ;-)
grandprixgtx00
04-10-2008, 01:30 PM
haha...sounds much easier than it really is, believe me. but the nice thing about doing a top swap on a GT (SE in my case) is that the L36 has higher compression, so it creates more power at a lower boost, therefor not needing a smaller pulley...
Google
Web AF
