DERM Code 1042JediKnight2 04-07-2008, 04:18 PM I took my Jimmy in for some other things today and they saw the airbag light on and told me that "Performed diagnostic test. Found Code B1042. Performed fault tree test and found DERM module signal fading in and out. Needs air bag module replaced." I assume this means the whole DERM needs replacing...since this is the whole system beside the passenger seat...is this something I can buy used out of a junk yard and install myself....part from GM is...SPENSIVE MT-2500 04-07-2008, 07:17 PM What year? Are you sure about the code no? Some states it is illegal to us used air bag or parts. MT JediKnight2 04-07-2008, 07:57 PM 1997 Jimmy Before I can do anything...I need to figure out how the passenger kick panel comes off...I have removed that panel underneath the glove compartment...the kickpanel doesn't have any screws though :banghead: MT-2500 04-08-2008, 09:41 AM I show it behind right kick panel. Does the code clear and come back? Is it a part time or full time code? Part time or intermediate code is usually a wiring problem. Proper testing first before throwing parts at it. I would check the derm wiring plug and wiring real close and for water or moisture getting in it. Use caution with air bags and wiring. Always disable the air bag system and do not use a test light or old type resistor volt/ohm meter to test circuits. If you need a repair flow chart for the code hit me a pm e mail and i will give you a pdf on it. JediKnight2 04-11-2008, 10:48 AM I ended up replacing the air bag module behind the right kick panel. Basically, I disconnected the positive from the battery, took the airbag fuse out...waited fifteen minutes...pulled the kick panel off and did the swap and hooked everything back up....air bag light stays off now after the test blinks. MT-2500 04-11-2008, 11:21 AM I ended up replacing the air bag module behind the right kick panel. Basically, I disconnected the positive from the battery, took the airbag fuse out...waited fifteen minutes...pulled the kick panel off and did the swap and hooked everything back up....air bag light stays off now after the test blinks. Thas for posting back how it went and the fix. Glad all is well and working good. MT JediKnight2 04-11-2008, 03:12 PM Dealer quote was 595.00 with the diagnostic....I paid 32.99 with shipping and 30 minutes of my time..... dugan50 04-11-2008, 09:09 PM Questions about airbag systems are asked a lot in this site. Check out this website for many of your answers http://www.airbagsolutions.com In addition, the purpose of this website and company is to help people diagnose and repair airbag problems themselves without taking them to the dealer (if possible). It offers all the photos and data you need to understand your airbag system, read the codes and reset the light. It’s a pay site, but it certainly is worth the money ($14.95 for 1 day full access) There’s a place to check if your car is listed on the home page http://www.airbagsolutions.com/vehicles_list.aspx and a working demo @ http://www.airbagsolutions.com/demo.aspx that shows just how easy these repairs can be. This is quite an extensive website with pictures, descriptions and factory fault code charts as well as videos of both accidents and airbag deployments on these pages: http://www.airbagsolutions.com/resources.aspx http://www.airbagsolutions.com/movie.aspx http://www.airbagsolutions.com/movie9.aspx It also has a lot of information for you to check your own vehicle, like the recall search pages for both the USA and Canada: http://www.airbagsolutions.com/nhtsa.aspx http://www.airbagsolutions.com/Canada.aspx Lots of insurance companies and body shops use this site for the information they need to repair your car. I hope I helped you vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
