'03 Chevy Impala, Check Engine Light, OBD II Code 420???
Google
Web AF
redddogg60
04-05-2008, 07:18 PM
OBD II , Code 420 (Catylist efficiency below threshold, bank one). Is this a catylitic converter problem, or a Oxygen Sensor problem, or something else??? Has anyone experienced this before??? Thanks in advance for any help you may offer.
Iflylow
04-06-2008, 06:15 PM
That rear O2 sensor is the one whose signal is used to determine cat function, so that might be a place to start. Usually a plugged cat will show up as poor acceleration due to the high back pressure. You can do a back pressure test to see.
BNaylor
04-07-2008, 12:48 PM
Possible but not necessarily. The CAT convertor can still have less than desirable oxygen storage capability, not be clogged/plugged and still trigger the P0420 DTC . The rear 02 sensor is most likely working properly since it is able to detect the CAT convertor low efficiency problem. In most cases P0420 indicates a CAT convertor issue so it may require replacement which may be covered under GM's emissions/convertor warranty depending on the mileage and age of the car.
Also, it would help to post which engine and mileage.
redddogg60
04-07-2008, 06:55 PM
This vehicle has 66k miles on it.
BNaylor
04-07-2008, 06:59 PM
GM's CAT convertor warranty is 8 years or 80K miles, whichever comes first so get it into the dealer for warranty work.
De-railer
04-07-2008, 09:47 PM
Yep have a dealer check it since it's still under warranty...they can do a back pressure test to see if it's clogged. It's sort of a common issue on these cars.
redddogg60
04-07-2008, 10:10 PM
Thank You For all the info.. Will make an appointment at the dealer. I'll update everyone with progress or lack of. THANKS AGAIN!!!!
redddogg60
04-10-2008, 07:34 PM
Converter was the problem. Covered under warranty 'til 80,000 (certain models are covered to 10 years/120K, per dealer). Thanks Again!!!!
Google
Web AF
