2003 S-10 4.3 vortec FUEL FILTER CHANGE 93,000 mliesS10SNODOG 04-04-2008, 10:26 AM Good day guy's I have a 2003 S-10 crew cab 4.3 vortes LS pick up ( 4 ft. bed ) I need to change out the FUEL FILTER any thing I need to know about like tools I NEED Since It has been over 94,000 miles will it be really hard to get it off and where is it located Thank You have a great day ! Anthony MT-2500 04-04-2008, 10:40 AM Follow the fuel lines etween the front of fuel tank and back of engine on left inner frame. Good 5/8 brake line wrench and a wrench to fit the fuel filter nut. Some 3/4 and some a hair bigger in metric size. Some fuel fliters have a qiuck coupler on on end. If so just squese the plastic clips and pull off. But use caution when taking the lines off. Disable fuel pump and let engine run untill it dies before starting. The are under some pressure or will always have gas run out. No smoking or open flames and use eye protection and keep you eyes and mouth closed and you ears plugged. Yes My son in-law got a ear full of gas one time. He wound up jumping in the swimming pool to wash it out. Good Luck MT vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
