1999 V6 Passat - stutters on accelleration
kooms
04-03-2008, 02:08 AM
I've had the car for two years without trouble. All of a sudden it's costing me a mint (at almost 125K miles). By the end of this month I will have put in $3,000 or more since the beginning of the year.
The current problem happens very intermittently. When we are going at low RPMs and accellerate quickly (like to pass another vehicle or go up a hill), the engine stutters/hesitates like it isn't getting enough gas. I have a VW shop (not dealer - independent) up the hill here. They first diagnosed it as a bad spark plug (caused by running low on gas, sediment getting in & fouling a cylinder). So replaced the plug ($120 repair). I drove it away and a few miles later the problem is there again. So back to the shop. This time they say fuel injectors - and I may as well replace all 6 since with the high mileage if one is failing the others may be following soon. So replaced all six (total $725). Picked it up last night & was running fine for me today but after about 10-12 miles, when my boyfriend got behind the wheel - he is a more spirited driver than I am - the problem showed up again. Every time the check engine light has come on (and stayed on). I don't want to keep pouring money into this car for mechanics to take stabs at fixing it. I found this VW shop recently but they seem reasonable (and are certainly saving me money over the dealer). If anyone out there has had similar problems and/or has ideas I'd really appreciate it, thanks.
If anyone in Seattle knows of a really good VW shop I'd love to know about that as well. //
bdazla
04-10-2008, 09:38 PM
I have a similar issue with my 99 Passat V6. There is a misfire under load but its fine when idling. So far I have replaced the plugs, fuel flow regulator, vacuum hoses, coil pack and the spark plug wires - which has not been cheap. Usually the problem leaves briefly but always returns, it shudders and you can hear a popping noise under the car. It is currently in the shop again and they cannot figure out what the problem is, sometimes the missfire is on cylinder 1, then 3, then 1 & 3. If anyone has any ideas i would appreciate it because I'm running out of parts to replace.
kooms
04-10-2008, 10:51 PM
Well, replacing the spark plug wires turned out to be the fix for me - sorry you weren't so lucky (and my misfires also varied between cylinders). Did your mechanic suggest the fuel injectors? Wasn't the answer for me, but who knows -
