View Full Version : what now?
what now?
savannaz34
03-31-2008, 02:01 AM
i found the problem with my oil pressure being so high,(SENDING UNIT)
now its normal,i changed the TPS SESNSOR,i cleaned up the map sensor bracket,checked for vaccum leaks,and i think my car is worse than it was before,i just cranked up my idle a bit (800 at idle when warm)just so it wont die on me for now.any ideas
oh,my engine fans dont kick in until gauge hits about 3/4 of the way
only if im parked and the motor is running
when im driving,its fine,doesn'tgo over half
any ideas would be appreciated
thanx guys
DnaProRacing
03-31-2008, 06:17 AM
the first fan doesnt kick on till a lil past half, the second fan kicks on at 240 degrees.
open your gas cap and see if it releases any pressure. if it does, you still have a vacuum leak somewhere. go to pepboys or autozone and pick up a pint of seafoam trans tune.
Related Links
Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free.
