'98 Bravada Maybe Starter?
oldsjoe
03-29-2008, 07:14 PM
Hello, and Thanks in Advance.
Yesterday I went for a long drive and on re-starting the car it started making a rubbing noise, like a belt was rubbing. I shut it off and it was as if the starter had never stopped starting and was winding down. I started it again and the same noise. I drove home because I was a ways away and needed to get back after about ten minutes of driving the noise stopped, my gauge lights flicked on for a second and the rest of the drive everything was fine. Now today when I tried starting the car, the gauge lights go on when I turn the ignition but the started does nothing. Doesn't even try. Is there something I can do, to find out the problem. I checked the fuses just to make sure it wasn't something simple. But, now I'm stuck. Not even sure where the starter is. Need Help.
Thanks,
Joe
Thanks,
Joe
Chris Stewart
03-29-2008, 07:31 PM
Yup, sounds like the starter contacts inside the starter solenoid welded together and spun the poor starter to death. I've heard about that for many years but haven't come across one yet...all help gratefully accepted.
The starter is mounted on the engine, lower passenger side/near the side of the oilpan.
