'98 Bravada Maybe Starter?
Google
Web AF
oldsjoe
03-29-2008, 07:15 PM
Hello, and Thanks in Advance.
Yesterday I went for a long drive and on re-starting the car it started making a rubbing noise, like a belt was rubbing. I shut it off and it was as if the starter had never stopped starting and was winding down. I started it again and the same noise. I drove home because I was a ways away and needed to get back after about ten minutes of driving the noise stopped, my gauge lights flicked on for a second and the rest of the drive everything was fine. Now today when I tried starting the car, the gauge lights go on when I turn the ignition but the started does nothing. Doesn't even try. Is there something I can do, to find out the problem. I checked the fuses just to make sure it wasn't something simple. But, now I'm stuck. Not even sure where the starter is. Need Help.
Thanks,
Joe
inafogg
03-29-2008, 07:28 PM
hey joe,if im understanding......it sound like the starter was still engaging even after car had started??if thats correct i suspect the solinoid may have stuck possibly burning up starter.ck for 12v at starter sorry not familure with car.if u have 12v have someone turn key & see if S terminal on solinoid is hot or just jump across the 2
BTW if starter did engage to long ck flywheel teeth,good luck let us no!!
Gabe25
03-30-2008, 04:54 AM
It really sounds like your starter is cooked. Like Inafoog mentioned. Test your starter for voltage. If voltage is there and starter still doesn’t work. You’ll need to replace it. Keep us posted.
Google
Web AF
