1996 Monte Carlo Starting Issues
teamcartman
03-29-2008, 12:36 AM
I have a 1996 Monte Carlo with a 3100 that will start fine when it is cooled off (as in over night). When the car is warm and has been sitting for less than 5 or 6 hours, it will not start unless I play with the throttle like it is carbeurated. Once it starts it will run rough and die. If I rev it up a little 2000-3000 RPM a couple times, it will then idle and run fine. It only happens at startup when warm. I never have problems with it once I get it running, or going down the road. I would like to keep this as cheap as possible, so id like to know if there is an idle control valve or something that could be malfunctioning when it is warm. Thanks a lot.
Lurchbiotch
04-07-2008, 06:32 PM
I have the same exact issue! And its driving me nuts! Anyone have any suggestions? Fuel pump? Fuel pressure regulator?
dragon_kin01
04-07-2008, 08:02 PM
ok guys here is a list of what could be wrong. the site also has a vechile repair guide and a how to section on it. run through the list and u can even price out the faulty part u find. http://www.autozone.com/servlet/UiBroker http://www.automotiveforums.com/vbulletin/images/icons/icon7.gif happy diagnosing
silicon212
04-07-2008, 08:48 PM
Sounds like leaky injectors, to me.
Lurchbiotch
04-07-2008, 11:25 PM
LOL that narrowed it down to EVERYTHING in the engine compartment. lol
slideways...
04-08-2008, 12:39 AM
i ran across a grand am 3100 a few years ago with the same problem. i really dont remember what fixed it, since my master tech at my shop finally got it right, not me. but i would check the coolant temp sensor, fuel pressure, check if the ECU throws codes, and check exhaust backpressure before the cats. for some reason i seem to remember a bad ECU, but i dont know for sure.
Lurchbiotch
04-08-2008, 11:03 AM
I checked my fuel pressure, its around 39-41 (Varies). The recommended Pressure is 41-47. What does that tell me? It drops between 3-10 psi when I start like the book says its susposed to. So regulator? Or pump? or do I just trade the car in? HAHA
teamcartman
04-08-2008, 03:15 PM
I think it is the Fuel Pressure Regulator, cause when I pull the vaccum line off and plug it, the car starts fine.
Ill post again when i get the time to go get the part and put it on.
