Dual springs question.666_speed 03-24-2008, 12:25 PM I have a question about the dual springs. I have tried searching and cannot find the answer I want. :banghead: With stock 241 heads on the LS1, what if anything would be required to run dual springs? Sorry if that seems dumb, because it probably is. Thanks for any advice. 666_speed 03-24-2008, 01:12 PM I'm looking at these, FWIW. https://www.patriot-performance.com/xcart/product.php?productid=102&cat=17&bestseller=Y EDIT: I called and these are what I need. Morley 03-24-2008, 03:40 PM Well, the ad says they are "drop in" springs, so you don't need anything more except for the tools to do the job 666_speed 03-24-2008, 03:47 PM Well, the ad says they are "drop in" springs, so you don't need anything more except for the tools to do the job Thanks. I just called them and asked. MrPbody 03-26-2008, 03:06 PM Unless you're planning to rev it to the moon, there would be minimal benefit from changing the springs. The "beehive" (conical) springs in LSx engines are excellent to 7,000 RPM for stability, and a lower seat pressure than more conventional springs. Based on the "numbers" in their advertisement, unless you've upgraded to a pretty serious cam, avoid them. Too much pressure and not necessary. Jim 666_speed 03-31-2008, 01:42 PM Unless you're planning to rev it to the moon, there would be minimal benefit from changing the springs. The "beehive" (conical) springs in LSx engines are excellent to 7,000 RPM for stability, and a lower seat pressure than more conventional springs. Based on the "numbers" in their advertisement, unless you've upgraded to a pretty serious cam, avoid them. Too much pressure and not necessary. Jim It's a 233/239 .595/.603 112 cam. It's pretty large. Thanks. z28 boy 03-31-2008, 02:12 PM I would suggest new seats and seals but other than that they drop right in. Unless you're planning to rev it to the moon, there would be minimal benefit from changing the springs. The "beehive" (conical) springs in LSx engines are excellent to 7,000 RPM for stability, and a lower seat pressure than more conventional springs. Based on the "numbers" in their advertisement, unless you've upgraded to a pretty serious cam, avoid them. Too much pressure and not necessary. Jim I wouldnt run a 918 style spring to 7k very often.....for 1 they have had a few set backs and there have been a few batches of bad 918's sold.....if one of them hoes breaks then u can drop a valve.......If u run a dual spring then u dont have to worry about dropping the valve cause u got the back up spring in the middle incase the outside spring breaks or vice versa.....i woulda gone with duals springs the first time around but i got these 918's real cheap. 666_speed 03-31-2008, 02:37 PM I have new seats/seals. Came with the kit. ANGER_TRAIN 03-31-2008, 02:50 PM It's a 233/239 .595/.603 112 cam. It's pretty large. Thanks. wow, that's a LOT of cam. good luck with everything. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
