1995 Cavalier ABS need some guidance
Google
Web AF
CzarVI
03-22-2008, 08:30 PM
The ABS on the car is messed up. It turns on at the most akward times and I lose braking power, ABS light is always on, going downhill activates it to turn on its very messed up. I just wanna turn the damn thing off, when its on it sucks anyways. Does anyone know what steps to take to turn it off? Should I just remove the power to it? Should I just turn it on in the fuse panel. If so can you point me to the location of the things I should remove to turn it off. Thanks for the help.
Classicrocjunkie
03-23-2008, 01:03 AM
You'll still always have the ABS off light on when you disable it unless you clear it out with HPtuners or a techII from GM.
Check the sensors are the wheels for debris/ loose connection
Is there tread on the tires?
Is it wet or snowy out when this happens?
CzarVI
03-23-2008, 03:48 PM
I dont mind if the Light is on, I can always find the fuse for it and remove it. The ABS doesnt turn on when its cold, sometimes I can force it to turn on if I break very hard soon after I start it. At this point the pedal falls through and you lose breaking power, but the next time you use it its fine. If I dont force it to turn on tho, a lot of time I will lose the breaks going downhill and this is the biggest concern to me. My mom drives the can and I dont want her to deal with that. The ABS system on these cars is horrible anyways so its not really doing a service being on. I just want to know how do I turn it off permenantly. Does anyone have a site I can look at or a couple pictures to help me locate what needs to be removed.
Google
Web AF
