Help please! 98 Monte carlo " ANTI-LOCK " light on all the time.
thakhek
03-21-2008, 12:18 PM
Any body know how to reset for turn off anti-lock light on 98 monte carlo please help. I know, I might have damaged the ABS system, for now I just want to turn it off untill the weather get warmer then I will try to work on it.
The reason it came on was my stupidity:banghead: . When the temperature is down around 10 degree or below this anti-lock light came on and off....
I thought it only cold weather cuasing it. I was wrong, very wrong. The brake fluid was low that why the light came on. After I added the fluid the light still on. Did I damaged the ABS system? Can I turn it off or reset it please help!!
Your idea,commens or instruction will be hightly applciated..
Thanks
TK
maxwedge
03-21-2008, 05:03 PM
The low fluid has no effect on the abs, only a scan with an abs function scanner will pinpoint the problem, no harm will be done driving with the lite on and if the rest of your brake system is in good order they will work normally even with the lite.
